586,058 active members*
4,681 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitty MC2 Yasnac I80M head scratcher!
    Feb 2013
    4
    We just bought/installed this machine on Thursday. It's my first Kitamura and my first Yasnac control.
    I love the machine, but the controller is proving a bit more challenging.
    So far, I've been able to "bully" my way through getting offsets arranged and what not. What I'm really struggling with is the LACK of a tool offset page that openly displays the diameter callout!
    All I can see is the tool height.
    I've been on the phone with Kitamura, Yaskawa, I have the manuals that came with the machine and the dowloaded PDF's from the site.
    Can anyone explain to me how to turn on/setup the screen so that BOTH Tool Height (G43 stuff) and Tool Diameter (G41/G42 stuff) can be seen on a single screen as illustrated on page 458 of Yaskawa manual TOE-C843-11.30F
    Any help would be appreciated very much.
    C.
    Feb 2013
    4
    Found it. It was a simple parameter change to separate H and D. Only took me till 2am to find it.
    Re: Kitty MC2 Yasnac I80M head scratcher!
    I have the same issue, would be nice if you would post the parameter you changed.
    Well I finally figured it out, no thanks to Longriflesinc. Called Yaskawa about some other questions and the tech had no idea about separating the H and D offsets, said I should contact Kitamura. I found it in the J300 user manual, thank you Yaskawa for having all of your manuals online!!!!!! It is pm4029 bit 0. Set to 1 separates H and D, set to 0 and they are the same input field. Fells like I just got a new machine.
  1. Yasnac i80m Alarm Code
    By PaulRP in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2020, 07:28 PM
  2. Looking for a Yasnac i80M Programmer
    By Alfonzo in forum Employment Opportunity
    Last Post: 11-27-2018, 05:43 AM
  3. 0TT-C head scratcher
    By wmpy in forum Fanuc
    Last Post: 05-28-2014, 01:47 AM
  4. Programming on a Yasnac i80m
    By SirDenisNayland in forum Parametric Programing
    Last Post: 07-24-2012, 12:18 PM
