603,882 active members*
4,655 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > How to invert slave motor direction?
    Jul 2003
    10
    I am using two motors and two drivers for y-axis (master and slave), how to invert the slave motor direction againt the master motor by only using one signal pin from printer port to both drivers?
    SC
    Dec 2005
    3319
    Switch leads at one motor????
    Don't forget to switch leads appropriately at servo encoder if so equipped.
    Swap motor leads on one winding only. Doesn't matter which one.
    Mariss
    Aug 2004
    104
    If you are using along with CNC, may exist one parameter for make the inversion at CNC.Check that. Of course this is conditioned to the CNC model.
