586,604 active members*
3,343 visitors online*
Results 1 to 6 of 6
    Mar 2013
    G0704 column bolts?
    Hi everyone, new to the forum and machining. Havent been in a shop since the old highschool days. I just got a g0704, cleaned it up, stand bolted to floor and the unit mounted on the stand.
    I aligned the spindle to the column and am working on (hopefully) aligning the column to the table. Looks like im .020 off but it appears I dont have the write size wrench for the column bolts.
    Does anyone know exactly what size alen/torx head they are?
    10mm allen iirc, I'll go doublecheck and report back if they are different.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    yep, 10mm allen.
    Hoss
    Mar 2013
    Excellent, thanks for the validation.
    no problem.
    Hoss
    Mar 2013
    Okay, I have another silly noob question. Ive got a DRO setup that im adding as well. Whats would you guys recommend for a bolt/thread size for attaching everything or isnt it that important?
  1. Eccentric bolts
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 07-27-2014, 02:18 AM
  2. Column gibb is binding on g0704
    By Nada mucho in forum Benchtop Machines
    Last Post: 02-02-2012, 01:27 PM
  3. Need dimensions for housing bolts (not mounting bolts)
    By rcpilot82 in forum Stepper Motors / Drives
    Last Post: 09-22-2011, 02:29 AM
  4. HSR rail bolts?
    By Gnu in forum Linear and Rotary Motion
    Last Post: 01-10-2007, 11:24 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
