603,884 active members*
4,536 visitors online*
    Sep 2004
    235
    Units Per Step For Servo
    Hi
    I`m converting my x axis to a servo and am wondering what the
    steps per unit would be for the motor tuning in Mach3. I`d like to
    have a resolution of .001 don`t know if this is possible.
    Servo 360 oz*in at 2175 rpm
    5 TPI Ball Screw
    US Digital Encoder 250
    Gear down ratio : 3 to 1 , 20 Tooth and a 60 Tooth
    There is a encoder setting counts/per unit in Mach3...I`m uncertain what
    I should use as a value. It looks like two values are needed, one for the
    motor tuning : units per step and one for the encoder. I hope I didn`t miss
    anything else.
    Thanks and Regards, Barry
    35494
    The encoder settings in Mach3 are not for your servos. Just do the motor tuning. I think 15,000 is what your looking for.
    250 in quadrature is 1000 steps per rev, X 5 turns per inch, X 3 for your gearing.
