588,443 active members*
5,103 visitors online*
    Feb 2013
    THC - torch height control
    Hi everyone.
    I have one question.
    - What software to CNC plasma controlling is best? Anyone has GALAAD ?
    - What Torch Height control is good ? Price PHC by Hypertherm is enormous (4500 EUR)...
    Thank you for your tips !!!
    Jan 2008
    2247
    The Hypertherm PHC height control system is a complete, turnkey height control that will work with almost any plasma on almost any cnc machine. It comes complete with the z axis torch lifter, motor, drive and operators control panel. It is designed to work with air plasma systems or high frequency industrial plasma systems. It has advanced features such as ohmic plate sensing as well as z axis motor torque sensing. This is a complete industrial quality control that is widely used on Industrial cnc plasma machines. It is the lowest priced, full function standalone THC available. Since this is a standalone design....the software that is used on the cutting machine is not critical...it works with them all.
    There are lower cost units that are simple arc voltage comparator circuits, however you will have to design and build your own z axis slide, drive and motor assembly, as well as working out the method of initial height (plate surface sensing) as well as pierce hight, cut height and pierc delay functions.
    Jim Colt Hypertherm
    Quote Originally Posted by hadacino View Post
    Hi everyone.
  1. DIY torch height control
    By mjp in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 06-15-2012, 08:24 PM
  2. Need better torch height control?
    By Karl_T in forum Waterjet General Topics
    Last Post: 04-27-2009, 05:36 PM
  3. Torch Height Control
    By luther in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-12-2007, 09:51 PM
  4. Torch Height Control
    By luther in forum DIY CNC Router Table Machines
    Last Post: 07-12-2007, 09:44 PM
  5. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
