586,116 active members*
3,556 visitors online*
    Mar 2013
    prima power platino machine issue
    we are using prima power platino model sheet metal laser cutting machine.Recently our machine resonator discharge tubes has blasted and we are in total mess without knowing the reasons.Does anyone here knows the possible reasons for the cracks and blasting of discharge tubes.
    Nov 2009
    314
    Hello ,
    We had YAG 1212 Machine with a laser generator ,which loacated a crystal located in the center . This crystal has a very important role and must be circulated with water all the way . Once no water circulated or water leakage can lead crystal blast for that moment . Hope this idea may help you get the reason .
    Best regards,
    XYZ Machinery
    Attachment 181188
  1. ONA Prima s 250 questions / problems
    By Thecerb in forum Waterjet General Topics
    Last Post: 01-29-2013, 08:41 PM
  2. BMC 20 power up issue
    By Rulunney in forum HURCO
    Last Post: 11-28-2012, 09:03 AM
  3. prima plasma inverter pp35 for cnc
    By baldthreads in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-08-2012, 12:54 PM
  4. ona prima graphic problem
    By rftools in forum EDM Discussion General Topics
    Last Post: 03-24-2010, 05:45 PM
  5. Ona Prima S900
    By fruivo in forum Waterjet General Topics
    Last Post: 07-05-2007, 02:19 PM
