586,102 active members*
3,343 visitors online*
    Mar 2009
    82
    Bridgeport series 1 MDI Heidenhain TNC 131
    Hi Guys,
    I've just got my series 1 MDI up and running after a long battle with a bad servo and some hefty replacement prices. My intention is to eventually ditch the old control and install 3 drives and run from a pc with the likes of mach3 or similar. Before anyone says, I know its a point to point machine and I know it can't currently do curves etc, but its a massive improvement in terms of productivity compared with my manual mill.
    I'm trying to use the Heidenhain TNC 131 control for now and I'm having some difficulties... I struggled to even get the machine moving with a program, but I have that covered now. I wanted to test out one of the canned cycles just to make sure the machine is working as it should be. I've programmed the tool def, tool call, cycle def, cycle call and got the machine completing its program with relevant M commands, the problem is the quill is feeding the opposite way (up)?? I know its something I'm putting wrong somewhere with the positioning blocks or something, but it would be helpful if someone could give me an idea on why I'm having this trouble please? I've had it working the correct way once, but couldn't find out exactly what I'd done right or wrong.
    Thanks in advance.
    Jun 2012
    30
    Assuming it's a pecking (drill) cycle, you need negatives on all the parameters to make it work properly, i.e. setup clearance should be negative, total depth, woodpecking depth - all zero. Otherwise your canned cycle will try to drill upwards... Oh, and don't forget you have to start the canned cycle from the clearance height (so if your clearance height is 2mm; make sure the drill is 2mm above the workpiece, and your canned cycle clearance is set to -2.
    There's a manual for your control here: TNC 131
  1. Bridgeport Series 2 Interact 2 Heidenhain TNC 155
    By rrossey in forum Bridgeport / Hardinge Mills
    Last Post: 11-30-2023, 01:10 AM
  2. Getting Bridgeport Series II Interact 2/Heidenhain TNC 151 running
    By maxvdh in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2017, 09:25 AM
  3. Bridgeport Series 1 Heidenhain TNC 145
    By pestana1957 in forum Bridgeport / Hardinge Mills
    Last Post: 01-02-2016, 07:47 PM
  4. Bridgeport Interact 4 Series 2 with Heidenhain TNC155
    By benspeed in forum Bridgeport / Hardinge Mills
    Last Post: 11-26-2012, 03:08 PM
  5. Bridgeport Series 1 Heidenhain 2500
    By exhausted in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2010, 06:58 PM
