603,884 active members*
5,112 visitors online*
    May 2007
    26
    Low Vibration causing the Z limit to switch
    I noticed that the low vibration on my bosch colt router is causing the Z limits to go off. What kind of limit switches are you using on yours?
    Jun 2011
    25
    Cherry snap action micro-switch w/ roller. Some of my larger machines I use hall sensors w/ magnets
    Jun 2011
    25
    Cherry snap action micro-switch w/ roller. Some of my larger machines I use hall sensors w/ magnets. You could also be seeing the effects of electrical noise from the router and/or steppers coupling into the pull up resistors on your BOB. You can try going into Mach3 and increasing the de-bounce time for your switches.
  1. Help with plunge cuts causing limit trip
    By btsioles in forum Mach Software (ArtSoft software)
    Last Post: 03-29-2013, 09:41 PM
  2. pulley causing vibration on feed screw?
    By KPNO in forum Linear and Rotary Motion
    Last Post: 05-25-2011, 05:50 PM
  3. What's Causing my Power supply to Current Limit?
    By blue_steel in forum Stepper Motors / Drives
    Last Post: 11-29-2008, 10:34 PM
  4. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
