587,998 active members*
1,596 visitors online*
    Jun 2009
    6
    Bridgeport series II interact 4
    Recently purchased one of these and I have a couple of questions. The Bridgeport manual is not very clear. How do I position the start point on the job manually? I have tried entering the co-ordinates into the x,y,z on the display but cannot get the table to go to that position. What am I doing wrong? Any help greatly appreciated.
    1121
    Use the handwheel [little wheel symbol on keyboard plus press the axis key for the desired axis] or use joysticks[this machine still has joysticks right?]
    Quote Originally Posted by skunge View Post
    Jun 2009
    6
    Thanks for the answer, yes it does have joysticks. I have now positioned the workpiece, so now I assume I zero the x & y axis on the display by pressing enter to make this the start position. I already have the machining program written, do I then call up the program and press start? I intend trying it on a piece of wood first to make sure there are no mishaps.
    1121
    IMO you need to read some manuals first.
    So I bought this car thing and I know the big roundy thing makes it turn but what do those pedals do? Guess I will just turn the key and figure it out as I go along..........
    Really, control manuals on the heidenhain site, interact manuals are around
  1. Bridgeport series 2 interact 2
    By Cyphertech in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2012, 05:33 PM
  2. bridgeport interact series 1 mk 2
    By skippyfix in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2011, 02:56 PM
  3. bridgeport series 2 interact 4
    By dcchip in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2010, 11:47 PM
  4. bridgeport interact 4 series 2
    By gideon233 in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2009, 03:05 AM
  5. Bridgeport Series 1 interact tnc 145
    By jaztau in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2008, 10:12 AM
