603,964 active members*
3,877 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Looking for quick bit of advice choosing rail thickness for basic wood router cnc
    Apr 2013
    6
    Hi, i'm planning to make a basic setup. It wouldnt really be right to call it a cnc but more of a router sled with x and y axis which I would move manually, however it would be build in a cnc style system.
    I've chosen to use round shafts for my rails but I can't find what thickness would be most suitable. I intuitionally decided 20mm would be suitable, however I do wish to keep friction and costs to a minimum so I would imagine if I can get away with lighter rails this would reduce weight for the x axis which would ride along the bottom y axis.
    The router I will use weighs 13.lb. If any flexing in the beam did occur I think I could probably tolerate perhaps 0.4mm. I would be using hardwoods, the working area im thinking about is 80x60cm.
    Can anyone offer advice? I've tried searching myself but I couldnt find much out there.
    Any help would be greatly appreciated.
    Nov 2006
    1036
    Perhaps someone with an engineering background could do real calculations for you. But I would think that if you used supported rails you could get away with something a lot smaller than 20mm. I used 20mm supported rails on one axis of my small router where the rails were bolted to 3/8" cold rolled steel which was bolted to a 3" x 1.5" 8020 aluminum extrusion. This is plenty rigid for my purposes.
    I'm not trying to spend your money but the 20mm isn't that expensive so you could overkill to be sure.
  1. Oil for lubricating rail on quick cnc
    By redvanth in forum Chinese Machines
    Last Post: 09-16-2012, 01:10 AM
  2. Basic Solution for CNC Wood Router Problem
    By omnicnc in forum Omni CNC
    Last Post: 09-13-2012, 06:18 AM
  3. Jinan Quick Router advice
    By cambridgecnc in forum Chinese Machines
    Last Post: 02-06-2010, 12:25 AM
  4. Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 02-04-2010, 04:59 AM
  5. Quick question about the y-rail
    By Jur1 in forum DIY CNC Router Table Machines
    Last Post: 01-06-2010, 04:52 PM
