586,266 active members*
4,047 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Feb 2010
    3447
    4th axis opinion - Ebay
    Originally saw these units from LMS:
    4th Axis Rotary Table for CNC - LittleMachineShop.com
    Then i searched ebay, and found similar units:
    CNC Router Rotational Rotary Axis A Axis 4th Axis 3 Jaw and Tailstock | eBay
    Anyone have one? Not looking at using this for production. Would like to use it for more small one off jobs in aluminum and plastic, and honestly just to learn and get comfortable with programming for a 4th axis. The belt drive should be adequate for what i have planned. I see it has a ratio of 1:8. With a little bit of re-engineering an additional pulley system could be added easily to multiply the ratio.
    Apr 2007
    8082
    Looks like a 3" or 4" chuck. Kinda small to me, but a larger diameter faceplate can be added when needed.
    CarveOne
    http://www.carveonecncwoodcraft.com
    Mar 2010
    115
    Looks exactly like the one that just showed up here via DHL last week!
    (just clicked your link... yup! Same seller)
    So far so good. Motor driver is almost exactly the same as my Wantai ones. Microstepping goes down to 800, and up to... ummm.. 25600?
    Very nice castings, everything looks and feels tight.
    Reduction is 8:1 (save YOU having to count it out like I did!). <-- edit: just noticed you mention that above!
    Belt cover is pretty cheap looking (maybe because... it is?!), but other than that everything else looks good.
    Feb 2010
    3447
    Thank you for the review. Did you purchase the one with the tail stock? Is the tail stock only good for longer items? If you have any youtube videos of it running or a review feel free to post them or add me on youtube, my user name is diyengineer
    Mar 2010
    115
    Yes - got the one with the tail stock.
    I wasn't going to bother at first, but then figured, for the small extra bucks now vs extra shipping later....
    Of course, your needs may differ.
    I don't have any videos of it actually in operation - but I guess that wouldn't be a huge deal to do.
    I'll think up something amusing to mill into something then shoot it.
    I'm user "DrFiero" on youtube (same as here, just no ".")
    Feb 2009
    2143
    How true does the headstock run in this kit?
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Mar 2010
    115
    Honestly, at this point I have no idea. I only got it a short while ago, and have been busy building up the rest of the mill at the same time!
    I'm at the point I'd like to start actually making something (other than more parts for itself). If I get a chance, while I'm shooting a test video, I'll grab my mag base and dial indicator and include a few random shots with that too.
    Feb 2009
    2143
    That would be great! Thanks.
    Feb 2013
    195
    those things are expensive! I bought extra motor to be able to add a 4th axis down the road, so I just need to figure out how to get the headstock put together. Harbor Freight has a small 2" Mini Lathe Chuck and a 6" Wood Lathe Chuck pretty reasonable. I'm thinking the 6" would be too large. Too bad they don't have a 4".
    Mar 2010
    115
    Quote Originally Posted by mcphill View Post
    Here ya go - this what you wanted to know?
    Mar 2010
    115
    Quote Originally Posted by diyengineer View Post
    Didn't. Now I do!
    Here you go...
    Mar 2010
    115
    Update on the runout video (I updated the video to reflect BTW).
    I grabbed various rods (mostly tooling bits) and chucked them up. I got very consistent readings across all of them, and saw up to 12 thou of runout!
    Same readings on all of the different bits, and all at the same point of rotation (so I doubt they're all bent at the same spot).
    What I shot yesterday was really only checking the backing plate, bearings etc. My bad.
    I should have checked the chuck as well.
    I'll just have to keep this in mind when doing 'stuff' that it better not be that tight of tolerance!
    I was mostly going to use it for artistic things anyhow, except for the odd gear.
    Dec 2004
    783
    Is the chuck a loose fit on the backing plate? Or have you taken it off yet to see? It shouldn't be too hard to dial it in, I ran across a HF 9X20 lathe with that much or more runout, just had to clean up the backing plate and locating ring to get something useful out of it.
    I would take the chuck off and check runout on the face and step of the backing plate.
    Sent from tapatalk
    Feb 2013
    195
    Quote Originally Posted by Dr.Fiero View Post
    Didn't. Now I do!
    Here you go...
    is that a blower you have on there?
    Mar 2010
    115
    Quote Originally Posted by Marti View Post
    Yeah! 6:71 Roots. Was going to go with the 8:71, but didn't want to seem pretentious.
    (of course, it could be the one that BD Tools aka Billy sells)
    Mar 2010
    115
    Quote Originally Posted by Dylwad View Post
    Good plan.
    So, took the chuck off the backing plate (bolted on with 3 8mm bolts, that are just a hair too long to be able to be removed without removing the backing plate). Runout across the face is fine. Runout around the inner locating ring is fine.
    Was in the process of checking the ID of the chuck where it meets the locating ring... when my calipers croaked. Sigh. It was looking good just before then.
    Anyhow, looks like I *might* be able to lightly ream the holes in the backing plate to give me some wiggle room. Then I can center it, and tighten it down (which of course will throw it off whack, then I can repeat forever! Heh).
    Feb 2010
    3447
    So the fix is to clean, loosen up bolts and ream them to allow adjustment? If you do make a how to video haha. Ill be buying in the near future!!
    Mar 2010
    115
    Guess mine was a monday morning, or friday afternoon production run.
    Hopefully yours was/will be made on a Wednesday.
    But yeah, if I get motivated enough to fix it, I'll try to film it.
    Feb 2010
    3447
    Thanks! Dr. Fiero, i checked all over Youtube and you seem to be the only one with that style off ebay. I'm sure you will generate some traffic on your video from others like myself searching for info about it. I'm sure with a little cleaning and realigning it will be well worth the money!
    Feb 2010
    3447
    Any luck on fixing it?
Page 1 of 2 12
  1. Z Axis Opinion
    By Rob K in forum DIY CNC Router Table Machines
    Last Post: 07-13-2014, 05:05 PM
  2. 4 axis machines on ebay
    By studysession in forum Commercial CNC Wood Routers
    Last Post: 02-03-2013, 11:46 PM
  3. eBay Chinese VFD spindle - Opinion ?
    By uspl in forum DIY CNC Router Table Machines
    Last Post: 12-01-2011, 11:03 PM
  4. opinion on ebay mini-mills
    By Smertrios in forum Benchtop Machines
    Last Post: 02-08-2006, 09:10 PM
