603,365 active members*
2,600 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Effect of small fillet radius and larger tool radius on pocketing
    greenene Guest
    I am curious to know how MC calculates the tool compensation when a fillet radius is smaller than the tool's radius. Can this cause MC to undercut a pocket? In a typical rectangular pocket, I usually make the fillets small enough to break the corners, not necessarily thinking about the tool's radius. In some situations, I know I will need to go in with a smaller tool. However, MC does not generate a tool compensation error, so I never thought about it.
    tony
    Dec 2008
    3211
    Basically
    -Mastercam would offset the wall contour by 1/2 the cutter diameter ( plus any additional offset ) at that cut depth
    - then it calculate the required passes. The path contour is done within the system and is not displayed
    For a internal radius that is smaller that the cutter radius, it would be eliminated due to the new tangent lines crossing before the that radius is formed
    - Mastercam does place a rad ( depends on operation settings ) in the corner that is marginally larger than the programmed tool, so that if a smaller tool is used with comp, it will not undercut and ruin the part
  1. fillet radius change
    By stude8 in forum BobCad-Cam
    Last Post: 12-20-2012, 12:14 PM
  2. Fillet Radius Question
    By Fighter in forum Autodesk
    Last Post: 12-17-2012, 06:52 PM
  3. Variable radius fillet mastercam X5
    By D.L in forum Mastercam
    Last Post: 03-06-2012, 01:47 AM
  4. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  5. Problem with variable radius fillet
    By gibsonc in forum Solidworks
    Last Post: 05-15-2006, 05:13 PM
