586,114 active members*
3,279 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 has stopped working after 6 months
Results 1 to 9 of 9
    Aug 2011
    73
    Unhappy G540 has stopped working after 6 months
    Hello,
    After 6 months of use, my G540 suddenly stopped working halfway through a job and is not responding to anything. The fault light is continuously on - even after re-powering a number of times. Very fustrating.
    Can anyone give me a tips to troubleshoot as I live in Melbourne, Australia and cannot afford to ship back to Gecko.
    Cheers, Richard
    Take the cover off, remove the motherboard and remove all four drives.
    Power up the removed motherboard with the main connector attached. If you get a green LED, you have a bad drive. A red LED means a bad motherboard.
    If green, then:
    Turn off power, plug in only one drive with no motor attached and power up the motherboard. If you get a red LED, you have found the bad drive. If you get a green LED, turn off power and plug in another drive with no motor attached. Repeat the process until you have tested all four drives.
    Mariss
    Aug 2011
    73
    Thanks Mariss,
    I'll follow your instructions this weekend and report back.
    Thanks Richard
    Aug 2011
    73
    Hi Mariss,
    I heard from a colleague that there may have been some issues with some revisions of the g540 when slaving 2 axes via Mach3. I recently changed my design to slave my y and a axes and it had been working ok for about 2 weeks before this failure occurred. I bought the unit from Homann Designs about 18 months ago, so could this be related?
    There is nothing you can do in Mach3 that can cause damage to any drive.
    Jun 2004
    6618
    If the slaving is what caused it, then there must be a wiring error. If it worked for awhile and now doesn't, I'd suspect an intermittent loose connection. If it was a loose wire on the motor side, it could damage the drive.
    Lee
    Aug 2005
    1094
    Quote Originally Posted by cnc3678 View Post
    Hi Mariss,
    If you return it to me, I can test it for you.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com/store
    Aug 2011
    73
    Peter,
    Thanks. I'll drop it off over the weekend.
    Aug 2011
    73
    Thanks to Peter, testing of the unit proved that there was nothing wrong. When I reinstalled it, it worked fine much to my surprise.
    I can only assume that there was a loose or crook connection, but I'd checked this already?
    Anyway, I'm back up v-carving again!
    Richard
  1. 3 Months, I Finally Got Mach3 to Talk to GeckoDrive G540
    By Darryl Hammonds in forum Mach Software (ArtSoft software)
    Last Post: 03-25-2013, 02:58 AM
  2. G540 Outputs stopped working
    By rk396 in forum Gecko Drives
    Last Post: 09-25-2011, 07:53 AM
  3. G203V Stopped working
    By LazyMan in forum Gecko Drives
    Last Post: 09-10-2009, 03:45 AM
  4. SX3 Stopped Working
    By mikemill in forum Syil Products
    Last Post: 01-09-2009, 04:54 PM
  5. Bandit stopped working
    By Chris64 in forum MetalWork Discussion
    Last Post: 12-18-2006, 02:02 AM
