With the power off you can also check resistance for 0 ohms from the top of the O/L terminal to the corresponding bottom terminal. Some O/L's are mounted separate to the contactor, others are integral, but same function.
With the contactor non-activated the reset should stay in, and only possibly pop back out when the contactor is picked up, if overload exists.
Al.
Albert E.
