The bladerunner manual is wrong when it comes to steps per.
Steps per is a simple number. Lets say you have 2-1 ratio with a 1" pitch diameter. That's (pi) 3.14 * pitch diameter divided by ratio then divide that number by 2000 gives resolution (1/10 microstep or like previously mentioned 1600 1/8). Then take 1 divided by resolution and you have your steps per.
So for a 1"pd with 2-1 reduction it would be 3.14*1 = 3.14 then divide it by 2 you get 1.57 then divide by 2000 you get .000785. For steps per take 1 divided by .000785 your steps per are 1273.88
12 tooth 24 pitch gear has a pitch diameter of .5"
This means You have a steps per of 1273.88 same as the example above but with no reduction and a smaller gear with a 1/10 microstep or .0009815 resolution or 1018.84 steps per with a 1/8 microstep.
This is per CandCNC manual
Calculating the beginning Steps per UNit on an AXIS
Use the following formala to get a ballpark steps per unit number in MACH
Psr = Pinion Speed increase ratio = Pitch Dia [in inches] * PI (3.1416)/1
Target Steps per Unit = (Psr X 2000)/Belt Reduction ratio
This will give you the required number of steps it takes to move 1”
From the manual you would get this result. .5*pi = 1.57/.5 = bad result. Should read pinion resolution = pitch dia*pi/ratio (if applicable)/2000. Resolution = 1/pinion resolution.
Now featuring Plasmaland online
