603,390 active members*
3,035 visitors online*
IndustryArena Forum > CAD Software > Solidworks > here's an interesting one. sheet metal part
    Mar 2007
    56
    so i have a sheet metal part that is 1/4" thick and has a jog bend in it. the jog gets a 3/16 weld fillet before bending and because the cut in solid works goes through a compund angle the fillet is causing the non-planer face of the jog to not be in line with the planer faces after bending.
    my instinct is to add the chamfer in solid works and let it do the math when i output the flat plan, but i can't add the chamfer till after the cut because there is no edge to chamfer before that. after the cut, of course the material i want is already cut away. lather, rinse,repeat.
    for the moment i've gotten down and dirty with the thing and measured the difference between the top and bottom edge and manually altered the cut line to reflect the position i want after the fillet is added. still waiting for water jet to see if it's workable, but even if it is it's a pretty dirty solution as it gives really bad results for the bend radii. one now has a point, and that's just not right.
    i can run a chamfer along the edge and see the problem but i just can't figure out how to fix this. i'm sure there is a way, some tool or something that i just don't know about...
    boss man didn't spring for maintinance so here i am.
    i'm sure that written explanation makes about as much sense as baby babbeling so i've got pictures and even the model for looking at. any thoughts would be welcome
    thanks
    Rob
    Dec 2009
    8
    Re: here's an interesting one. sheet metal part
    Did you get this solved? I'm not exactly sure what you're trying to do, but I would think you would have more control of the problem if you used the unfold/fold tools and then an extruded cut to remove exactly what material you want to remove, rather than relying on the chamfer tools limitations as you've already encountered. Is this chamfer something you're going to machine or grind in after cutting or do you have access to a 4 axis water jet or laser of some sort?
  1. Need quote for a small sheet metal part with one bend
    By cpy911 in forum North America RFQ's
    Last Post: 07-10-2015, 02:31 PM
  2. Rolling a flat sheet metal part.
    By diyengineer in forum Solidworks
    Last Post: 04-12-2013, 12:28 PM
  3. sheet metal part problems
    By chadwiggan in forum Uncategorised CAD Discussion
    Last Post: 08-22-2010, 12:15 AM
  4. Turning tube into sheet metal part?
    By bearracecars in forum Solidworks
    Last Post: 08-14-2009, 04:36 AM
  5. What is best for sheet metal part modeling?
    By REVCAM_Bob in forum Uncategorised CAM Discussion
    Last Post: 01-25-2008, 06:05 PM
