586,785 active members*
3,224 visitors online*
    Apr 2013
    24
    Looking for a Driver and breakout board
    Hi everyone,
    I am looking for an driver and breakout board for my 3A steppers it is 6 leads bipolar
    I had very bad experience with Tb6560 based driver so I am looking for something more reliable
    Is this one is good
    Luc's THB6064AH driver
    But I can't understand what are the components of its breakout board it seems like it just connecting a LPT and a 5V regulator?
    Can you recommend on a driver and breakout board that will suit my steppers?
    Thank you!
    Dec 2007
    2134
    The 6064 is a far better driver for bipolar steppers than the 6560, but at $35 an axis plus BOB it's creeping up?
    I believe these chips are a much more adequate design, and better suited to cnc.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Apr 2013
    24
    It is a bit expensive but I can't see another alternative for good drivers for the same price
    364
    Your experience with the cheap TB6560 was even more expensive: money without result = wasted.
    Pay a bit more for a well designed drive and BOB with garanteed support.
    There are several flavours of design for you to chose the one wich suits you best.
    Open source CNC electronics and accessories:
    http://users.skynet.be/ldt/CNC%20electronics/THB6064AH.html
    May 2005
    1397
    Note the price is $30 each when buying 3 or more. And the price is what it is because we use quality components. The current sense resistors and big power cap are examples; high quality, more costly, worth it.
    The BOB is simple, and it works. And it's not just connections and power: It also hosts a relay driver for the spindle. My experience is that opto-isolation causes more problems than it solves, but if you want a compatible open source BOB with opto-isolation, check the PMinMO.com site.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. make your own breakout and driver board?
    By crob09 in forum Open Source CNC Machine Designs
    Last Post: 11-22-2015, 05:47 PM
  2. Stepper driver, breakout board problems
    By dougie329 in forum DIY CNC Router Table Machines
    Last Post: 08-16-2011, 10:59 AM
  3. Wiring Stepper, driver and breakout board
    By bdrotaru in forum Stepper Motors / Drives
    Last Post: 02-26-2011, 06:30 PM
  4. Driver and Breakout board troubleshooting
    By vmipacman in forum Automation Technology Products
    Last Post: 07-06-2009, 11:22 PM
  5. does this driver need breakout board?
    By dreamci in forum CNC Machine Related Electronics
    Last Post: 09-30-2008, 10:49 PM
