587,837 active members*
3,526 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Wiring Stepper, driver and breakout board
Results 1 to 7 of 7
    Mar 2009
    36
    Hi.
    Recently I purchased SP705 power suply, M880A driver, 57HS22 stepper motor all from Leadshine and breakoutboard
    from next image
    http://img.alibaba.com/img/imagerepo...er2_132260.jpg
    I will get 5V from USB.
    Please help me configure driver, wiring motor to driver and configuring EMC2 or Mach3 to do a simple 1 axis test
    Thank You in advance
    May 2005
    1397
    Err... does the mfgr you purchased the driver, etc... from not have that documentation? Wow...
    Something has to tell you which parallel port signal goes to which P# on that break out board. If there are no docs, you will probably just have to tell your CNC software to put a signal on a pin, then run some sort of job that exercises that pin and look for a signal with a meter or logic probe down the line of P# pins.
    Then you need to figure out which pin is which on your stepper motors. If there are no docs, this page may help:
    Stepper Motor wiring
    Mar 2009
    36
    wiring
    I have the documentation. but moor doesen't move a bit
    I have W7 - 64 bit and mach3. I think Mach3 is not compatible with x64 environement. So i tryít in ubuntu x32 and emc2 but still no result.
    I think is a wiring problem.
    Mar 2009
    36
    the wiring i made
    This is the wiring i made
    The motor is 57HS22
    What is worng
    And what is the mach3 settings
    Or EMC2???
    Apr 2009
    134
    Did you find solution to your problem?
    I am waiting the same board to arrive,your wiring looks ok to me.
    Did you try to change active low/high setting in mach3?
    Why nobody connects enable pin on this drivers?
    Apr 2009
    134
    Found the manual for this DB25 breakout board if anybody needs it:
    Attached Files Attached Files
    Feb 2011
    How do I connect an old stepper driver with cwp +, - and ccwp +, - to a new break out board with pulse, com, and step? Should I use a flip flop that will send the pulse to cwp + when dir is high and ccwp + when dir is low and connect cwp - and ccwp - to com?
    Also, does anyone know if and how I can add optical feed back into my breakout board? I'll attach photo's of my breakout board and stepper driver with labels.
    I also have some other questions I have posted in my blog and would appreciate any help or direction, so please feel free to visit my blog on my punch press project.
    Attached Thumbnails Attached Thumbnails breakout board.jpg   2011-02-07 17.08.16.jpg
  1. Stepper driver, breakout board problems
    By dougie329 in forum DIY CNC Router Table Machines
    Last Post: 08-16-2011, 10:59 AM
  2. Help Newbie convert wiring from DSP to breakout board
    By JohnCo in forum Australia, New Zealand Club House
    Last Post: 11-03-2009, 08:11 AM
  3. does this driver need breakout board?
    By dreamci in forum CNC Machine Related Electronics
    Last Post: 09-30-2008, 10:49 PM
  4. Wiring Breakout Board Questions
    By Dingo745 in forum Xylotex
    Last Post: 03-31-2008, 08:47 PM
  5. Stepper Driver, Controller, Breakout board, Home switch, ?????
    By perolalars in forum CNC Machine Related Electronics
    Last Post: 10-28-2007, 03:35 PM
