603,383 active members*
3,732 visitors online*
    Dec 2011
    29
    Mazatrol cam T-2 corrupted memory/parameters
    I have a Mazak QT8 - Mazatrol cam T-2 lathe.
    It was powered off more tan 8 months. When I was testing the machine and it worked fine for one or two days, but then it started to fail showing some alarms:
    200 termal trip emergency
    202 hydraulic pressure down,
    1 servo lag excess x axis, etc
    Sometimes the screen dessapeared with a white cursor blinking on top.
    I called the technician for some help. There was some corrupted parameters in screen (a lot of "*****") and we decided reset the FX701 card. I entered all parameters and it was ok. But yesterday the alarm '22 NMI Memory parity' appeared when I was programming for testing, and the MCUAL led turned ON, also the RAMP turned ON.
    Finally I decided to replace all the batteries although no battery alarm led turned ON.
    Now the parameters are corrupted again and I can't reset the system. As well as I remember I restarted all parameters with switch ST1, but it didn't solved the problem. I prooved with XIC 2nd dip switch ON--->power on--->XIC 2nd dip switch OFF. But a lot of parameters still showing '*******'.
    I supose that after the batteries or capacitors are discharged I just have to enter new parameters. When I try to change some parameter the alarm '488 Operation not allowed' appears. I can't contact the technician and I don't know if I forget some procedure, or the PCB is bad. but I remember that it is the same problem, but i can't reset the parameters or all system.
    Thanks for your help!!
    Dec 2011
    29
    Dec 2011
    29
    I solved muy problem re-initializing controller.
    Many thanks to the person who helped me.
    Jhoan
    Quote Originally Posted by jhoanrojas View Post
    Jhoan
    Jhoan,
    Am currently have the same issue and I lost all my parameters on my T8, is there anyway you could shine some light please
  1. CHNC w/ 810 control parameters get corrupted after power off
    By EFI-Unlimited in forum Hardinge Lathes
    Last Post: 03-16-2025, 06:01 PM
  2. Mazatrol CAM M2 Memory Upgrade
    By PrecisionD in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-23-2021, 03:54 PM
  3. 1990 VF1 Parameters Corrupted?
    By ChuckMTB in forum Haas Mills
    Last Post: 10-01-2011, 12:24 AM
  4. Memory upgrade for Mazatrol T32-3???
    By Fendertok in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-10-2006, 08:25 PM
  5. series 1 nc, memory corrupted?
    By tpretto in forum Bridgeport / Hardinge Mills
    Last Post: 10-04-2006, 02:31 PM
