603,319 active members*
2,768 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > HITACHI HT25S Z AXIS ISSUE
    Feb 2008
    28
    Attachment 192106Hello All,
    Most of the time when I start up the 1988 Hitachi Seiki lathe with a MULTI Control, I get these Alarms after I press the STAND BY button,
    ALARM 392 Z-AXIS TG DISCONNECTED
    ALARM 390 SPINDLE TG DISCONNECTED
    ALARM310 POWER FOR SERVO NOT SUPPLIED
    ALARM 280 NOT READY
    The machine fires up sometimes others it goes in to the above alarm states.
    Could someone help me with what could cause a intermittent issue I am having.
    Thank You Skeney
    Dec 2009
    559
    Skeney,
    sounds like the power supplies for the control and drives are getting old. Usually, they energize in the time it takes to walk from the main power to the control, and are ready to fire up once you power on the control. When they get older, they take longer to energize so the control becomes "ready" before the axis and spindle drives have fully energized. What kind of spindle / axis drive does it have? Yaskawa?
    John
  1. Hitachi Seiki Multi HT20SII RS232 issue
    By Datu in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-13-2017, 08:48 PM
  2. Hitachis-Seiki HT25s Spindle issue
    By OrMach in forum Mori Seiki lathes
    Last Post: 10-09-2012, 05:44 PM
  3. Hitachi X200 and 2.2kw spindle issue
    By henrikm in forum DIY CNC Router Table Machines
    Last Post: 03-18-2012, 01:57 PM
  4. Hitachi Seiki VM50 Seicos Lambda- memory issue
    By robert0707 in forum Mori Seiki Mills
    Last Post: 01-25-2011, 07:44 PM
  5. Hitachi Seiki CS 40 Lathe issue
    By mcintys in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2009, 05:10 PM
