586,103 active members*
3,703 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Gecko 540 and a chinese 2.2 kw water cooled spindle and vfd
    Jul 2012
    159
    when I bought this spindle it said it was controllable by the computer for turning on and off and speed control, also said a manual would come with it.
    Well I got the spindle and vfd and a piece of paper, no where does it actually show how to hook it to anything to control the vfd. Anyone have a idea how to do this. I got it from buildyourcnc.com
    Thanks for the help.
    24221
    I am assuming this is a Huanyang VFD?
    There is a manual on a few sites on the web.
    Did you contact the supplier?
    You should have got a manual with it, although if Huanyang it is cryptic.
    Plenty of recent posts here if you search.
    Al.
    Albert E.
    Jul 2009
    9
    Try this guys thread for Mach 3 he uses a USB to rs244 converter Shows the sources and pictures has the Mach3 plugin for down load. He even shows a video on youtube of it working.
    Mach3 plugin for Huanyang VFD | Le royaume d'éole
  1. Water cooled Chinese spindle disassembly
    By rusel in forum Spindles / VFD
    Last Post: 08-28-2019, 07:07 AM
  2. A Look Inside a Chinese 3.0kW Water Cooled Spindle
    By kevincnc in forum Spindles / VFD
    Last Post: 05-02-2019, 02:57 PM
  3. Water cooled Chinese Spindle - air leak
    By analogman in forum Spindles / VFD
    Last Post: 06-23-2016, 02:08 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
