586,123 active members*
3,237 visitors online*
Results 1 to 6 of 6
    Jun 2013
    15
    How to Attach to wall
    Is there an official way to attach t slots to the wall or stud?....or do i just drill a hole and run a screw all the way across from the slots to the stud?...thank you
    Jan 2010
    485
    That will work, or you could use the angle iron clamps the sell. Or make your own from angle iron.
    Jun 2013
    15
    Jan 2010
    485
    Jun 2013
    15
    Thank you very much sir...really appreciate it..
    Apr 2013
    actually, while one could do it using either the brackets or a lag screw to wall approach (ive done this myself), ive found that the approach that works best is to take the specific floor mounting brackets appropriate for the t slot extrusion you're working with, and mount that bracket to the stud, as if it were the floor. this gives you the ability to adjust and level, as these brackets are designed to allow one to level and true the captured extrusion.
    i can post pics and part numbers later today if you need further clarification - im currently building a 80/20 based workstation framework the attached to both my concrete floor, wall studs, and my very heavy woodworking bench, all of which provides increased rigidity, but all of which must be kept squared, as accurate cutting and measurements are kinda important to me ;-)
  1. How to attach carbide ?
    By Ramu in forum MetalWork Discussion
    Last Post: 06-20-2010, 06:27 AM
  2. Attach Laptop to CNC
    By nk27 in forum DIY CNC Router Table Machines
    Last Post: 10-20-2009, 11:45 AM
  3. How do I attach anything to an X3 head?
    By slashmaster in forum Benchtop Machines
    Last Post: 05-09-2009, 06:09 PM
  4. How to attach flat to box?
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 12-22-2006, 07:44 AM
