603,834 active members*
3,388 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Does the Tormach use a signal generator?
    Sep 2011
    474
    Im curious about the step frequency generated by the Tormach controller. Does it use any kind of step generator or processing outside of the PC, or is it limited by the kernal speed? Seems hard to believe it runs straight from Windows, which doesnt run in real time.
    Mar 2008
    216
    Quote Originally Posted by SwampDonkey View Post
    Essentually none of the above. A hardware timer (that is available in all PCs) is used to generate periodic interrupts. The interrupted CPU then
    applies the required step on each axis that is moving. Hence Windows only has an effect on the interrupt latency and not the stepping frequency.
    It is also required that the Windows setup disable all non-essential CNC applications, like networking, etc. This results in a very low latency and
    reliable operation.
  1. TM1 Signal Generator Alternatives
    By runlevel6 in forum Torchmate
    Last Post: 05-14-2021, 04:52 AM
  2. signal generator problem? TM2
    By Geo-Con in forum Torchmate
    Last Post: 03-09-2015, 02:21 AM
  3. Signal generator need help
    By kirkln in forum Torchmate
    Last Post: 12-10-2008, 02:30 PM
  4. Low cost portable signal generator
    By i_am_fubar in forum News Announcements
    Last Post: 09-04-2008, 04:28 PM
  5. SIGNAL GENERATOR 501A
    By ecamacho in forum Torchmate
    Last Post: 01-18-2008, 10:57 PM
