586,108 active members*
3,328 visitors online*
Results 1 to 6 of 6
    Jun 2013
    15
    Meaning of N in load max spec
    im trying to find out what " - Load max. - 5000 N" means in this technical data sheet...
    TECHN. DATA / ITEMS SUPPLIED
    - Aluminum cast, powder coated gray
    - 2 anti rotation elements
    - 2 M8x20 socket head cap screws
    - 2 M8 square nuts
    - Weight - .263 kg
    - Load max. - 5000 N <--------------
    would like to see if any one could help me with his one...thank you...want to make sure how much weight i can put on it...
    Jan 2010
    2141
    Feb 2009
    2143
    Correct. 5000 N is about 1100 pounds.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Jun 2013
    15
    wow would of never guessed it...so basically its 1 ton and 100 pounds...thank you so much
    No, 1 ton is 2000 lbs.
    Feb 2009
    2143
    Because it is close to 1000 kg (a metric ton), which is 2200 pounds...
  1. Replies: 2
    Last Post: 07-08-2011, 03:03 PM
  2. G201X LED color and meaning.
    By curriergroh in forum Gecko Drives
    Last Post: 04-13-2011, 02:28 PM
  3. DMU 125P, meaning of M51 code
    By metus in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-20-2009, 01:40 PM
  4. Meaning of G28?
    By kotten1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-07-2008, 11:59 PM
