603,348 active members*
3,363 visitors online*
    Maximum Workpiece Material Weights for a CNC Lathe
    Hi Everyone
    I just wanted to check whether any of you know what the maximum workpiece weight for a CNC lathe is. The machine I am currently using is a QuickTech GT4-42S CNC Lathe. I require both the Main Spindle maximum workpiece weight as well as the Sub Spindle maximum workpiece weight. I have tried to find these specs on the internet but have had no success. Please let me know anything that might help or let me know should you require any additional information.
    Thanks again everyone
    Richard Morcom
    According to the QuickTech website 155.0 mm is the max turning length by 100mm dia. I doubt you need to worry about weight.
    Products - Quick-Tech
    BTW you posted this in the wrong section :P
    www.decalpro.ca
  1. X3 Component Weights
    By miseree in forum Benchtop Machines
    Last Post: 11-24-2009, 04:34 PM
  2. Ideas to isolate workpiece from waste material
    By RiceCustomRich in forum Rhino 3D
    Last Post: 08-22-2009, 08:01 AM
  3. Removing backlash on X & Y by using weights?
    By svarzaru in forum Benchtop Machines
    Last Post: 02-24-2009, 02:54 PM
  4. maximum lathe spindle bearing speed?
    By ScottC in forum Mechanical Calculations/Engineering Design
    Last Post: 01-29-2007, 01:15 AM
  5. counter-weights
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 02-15-2004, 03:56 AM
