586,105 active members*
3,261 visitors online*
Page 1 of 5 123
Results 1 to 20 of 84
    Aug 2004
    61
    kurt vise quality?
    Well after waiting with anticipation for my non import quality d675 AngLock Kurt vise, it came in. The first thing I noticed is how beautiful it looked,The second thing I noticed is that there was considerable play side to side on the movable jaw.
    So, I grabbed a feeler gage set and started with a .010" and kept working my way up until, no kidding, 0.025" before I finally couldn't slip it in between the middle guide and an inside rail. So I wrote a letter to Kurt mfg. and am presently waiting for a reply.
    Before I get too upset about this, could I get some people to measure the side to side play on their Kurt d675 vises so I can have a better idea of what is normally out there. Meanwhile, I'll be waiting for a reply from Kurt mfg.
    Sincerely,
    Frank
    Apr 2003
    348
    I say your good to go that .025 in there so I will hold unparallel parts better.
    Aug 2005
    1622
    I will second that! The movable jaw has some float to allow for minor misalignment. If it were rigid and didn't clamp parallel, it would be worse and you would be less happy.
    The stationary jaw and seat are the control surfaces. If the head is trammed and the stationary jaw is indicated to the desired axis. No real issues should come of that .025. In most situations, one should never rely on the front jaw for repetitive part orientation.
    DC
    Aug 2004
    61
    Thanks for the input. I may do some modifications though, to make the amount of slopiness adjustable in order accomidate the type of work I do, which is quite often small parts that are easier to grab on one side of the vise.
    Frank
    Apr 2003
    348
    I see your point you could put one small part on the other end of the vise jaw to keep it parallel when clamped
    Aug 2004
    61
    Yes, though it seems a bit of a shame. With drill press vises I can understand having to do that.
    I'll be interested to see if Kurt ever answers my email, and what they will say. I hope maybe they will listen to feedback, and improve the design further.
    Frank
    Aug 2004
    2849
    So, will the Kurt be better then the $75 Phase II that ENCO is offering?? How much better??
    tighten the set screw on the backside of the moving jaw ,beleave its a 1/4 '' hex , if you loosen that screw right off you can remove the jaw for cleaning and maintenance porposes , kurt always has some slop or it won t move ,
    the trick to using a kurt vise is , when you want to cut step jaws clamp on a parallel directly below where you are going to cut the step , to compensate for the lift ,this way you are assured acurracy when you clamp down on your part the lift shouldn t be an issue , and if you keep a consistant clamp pressure between parts you should aquire a fairly consistant parallism
    keep the set screw snug ,because when you are clamping with hard jaws the fixed jaw will be square to the bottom of the vise , the moving jaw however will lift and no longer be parallel to the other jaw especially when you are clamping high in the vise , this will cause your part not to have even clamping pressure and the jaws will have a tendancy to push the part out , and even more so as you apply more pressure
    kurt vises are bullet proof , after a while you ll be glad you didn t buy imports
    next time look at CHICK vises dont let the price or the aluminum scare you , they work the opposite the more pressure the more the jaw sucks down , they don t lift , and in my opinion they are the best
    Aug 2005
    1622
    Quote Originally Posted by jed102
    Frank
    The level of precision in a high quality work horse vise verses a super precision toolmakers vise is quite different. Matching ones level of expectations with first hand knowledge, limits these kind of disappointments and surprises.
    As a simple fix to the moving jaw slop. For my mill vises and even horizontal saw vises. I have made offset extented jaws that have a swivel foot screw(robbed from a De-Sta-Co clamp) into the face of the moving jaw on the extended end, for just this purpose. I can mount them to the right or left by swapping the front/rear jaws . They can be .5-1" wider on one end to facilitate room for the screw and a lock nut on the exposed rear face. Adjust it to suit the part being machined on the other end. Basically I did this because the dummy part would fall out, or just be plain inconvenient PITA.
    A bit off topic.........Using the same principle as above. Most horizontal saws always seem to have the jaws so far away from the blade. Making small chunks impossible to trim. I made up some slightly larger false jaws from 3/8 CRS plate that extend out past both ends of the original jaws. The blade end, was cut to after final install with CS cap screws. The opposite end has the swivel foot screw to keep the jaws parallel when gripping short stock. With care, this makes it possible to trim off some parts with less than a 1/4" grip.
    Give it a try. It'll make you happy CLAMPER too!
    DC
    Jan 2004
    3154
    You also have to figure that the D675 is Kurts general purpose vise, I bet that the CNC qualified units wont have that much play.
    I (so far) have been too cheap to buy the CNC vises, but I have 3 D675 and 1 D688 and the are superb, all of my other vises went for scrap metal. My oldest D675 must be about 8 years, these are great units.
    www.integratedmechanical.ca
    Aug 2004
    61
    Unhappy
    Thats interesting about the Chick vises pulling down as you tighten! Kurt apparently allows the use of O rings under the movable jaw to somehow achieve the pull down effect.
    Also, I may try something like DCs' idea to deal with the clamping of small parts on one side of the vise where that .024 side play will cause trouble. As far as buying one of Kurts cnc vises goes, I simply can't afford stuff like that at this point
    Frank
    Apr 2003
    348
    Frank
    I checked 3 Kurt d675 vises with a feeler gage the best one was .004 play side to side on the movable jaw. and the other two had .006 & .008 the newess one is 6 years old.
    mitch
    Aug 2004
    61
    Thanks Mitch! It seems that perhaps their quality control has gone down hill since 6 years ago, considering I have .024 side to side play on my brand new D675.
    Anyone else have some interesting news? If I get enough feedback of this sort I will have something substantial to bring to Kurt.
    Frank
    Feb 2006
    313
    Curiousity got the best of me and I had to go check. My thoroughly used and abused 1981 jet vise will just accept a .007 feeler gage. Perhaps that comparison will help motivate kurt
    Tiger
    Aug 2004
    61
    Wow!! Jet just went up a notch or two in my books.
    Feb 2006
    313
    Don't overestimate jet... I had the advantage of living in seattle when all jet tools passed through that port and I went down and hand picked my stuff at their outlet store. Most of what they were selling started out sloppier than mine ended up.
    In fact, some of the most horrendous fits and finishes I've ever seen were on the jet tools in that warehouse. I recall one tool and cutter grinder that had the main dovetails grossly mismatched... 60 degree dt on the base and the table dt were euro style 55 degree, but it was all mated up and for sale that way... including the bonus .080 (approx) airgap on both sides LOL
    Tiger
    Aug 2004
    61
    Point taken. LOL is right!
    Frank
    Aug 2004
    61
    .024 side to side slop on my new D675 kurt vise! I can not properly/precisely grab work pieces at the side of the vise without trying to find a piece of material the right size to put in the other side (sort of like a drill press vise).
    I would be interested to know if others have the same amount of side to side play to determine whether or not it is just a quality control slip up or not on Kurts behalf. So far it seems that older D675 vises have much less slop. Any input would be appreciated.
    Frank
    1121
    drill and tap a 1/4-20 on each end of the vise jaws and use a jack screww on theopposite side from your work, and leave it .01 small
Page 1 of 5 123
