586,103 active members*
3,013 visitors online*
    May 2012
    15
    ez trak axis drives off
    hi all
    having a little trouble with my mill was working fine .switched on in the morning homed the axis jogged back to centre
    trammed the head and left the machine for about 5 hrs came back to start work and got an error maessage of axis drives off press any key .i now cant get any power to axis .have tried turning on and off but will not home just repeats the same error .
    all help appreciated thank andrew
    May 2012
    15
    have now gone alittle bit deeper into this problem both drive boards have the red and green leds on when you press to home you can feel a small pulse on the hand wheels of the mill the model is a bmdc with a flash drive
    Jun 2007
    129
    You should be able to select power on and jog each axis. The one that will not jog probably has a bad drive card. You can swap the control leads between the drives or just swap drive positions. If you have a 3 axis and it does nothing, probably the z axis. For a 2 axis, probably the y axis.
    May 2012
    15
    whats the procedure for power on i've not used this procedure tet
    thanks andrew
    Jun 2007
    129
    If I remember correctly, if you get the power off error prior to homing, you can select #7 and it should power the drives allowing you to jog the axis. If you attempt to jog the axis with a bad drive, it will give the power off error. Keith from Versitech was working with me on my drive problem and I think that is how we did it.
  1. convert ez trak 2 axis to 3 axis
    By john_hoek in forum Bridgeport / Hardinge Mills
    Last Post: 12-09-2010, 01:02 AM
  2. EZ TRAK OFF IN Z AXIS
    By dmac88 in forum Bridgeport / Hardinge Mills
    Last Post: 07-08-2009, 06:22 PM
  3. post for 2 axis ez trak versus 3 axis ez vision
    By tooolman in forum G-Code Programing
    Last Post: 11-28-2008, 10:33 PM
  4. 4th Axis for EZ Trak
    By Grayling in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2008, 07:05 PM
  5. EZ-TRAK SX stopped seeing drives(FDD,HDD)
    By mrnicks in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2006, 07:05 PM
