586,116 active members*
3,469 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Need help with my electronics for a DIY CNC router
Results 1 to 9 of 9
    Jul 2013
    4
    Hi Good Day to all,
    I decided to build my own cnc router and i got a package off ebay with the following.
    -Brake out Board
    -Longs S-201-60 Power supply (+60v 3.5A)
    -Longs DM860A Driver
    -Longs Stepper motor model 34HST9805-37B2
    -used 5v supply from pc power supply
    i am using Mach3 to run it, i have windows 7 32bit installed on a dedicated pc for this project.
    I hooked it up but got no movement at all, i am not even sure if i hooked it up correctly, or if i configured mach 3 correctly. Is it possible for someone to guide me through this wiring/ config process?
    thanks
    Saalih
    Oct 2010
    26
    Hi Saalih,
    One question: Does your version of Windows 7 permit you to use a parallel port. All the ones I have seen do not recognize the parallel port, even if you add a board.
    I had to use Windows XP. Then everything went fine afterwards.
    Have fun with your machine!
    Piertechpierre
    Jun 2013
    88
    An Ethernet Smooth Stepper will allow you to use windows 7 and Mach3.
    Jul 2013
    4
    thanks for the replies.... my windows 7 sees the lpt port and also the driver for mach3 installs without any problem.... i think the first part to start off is with the wiring... i dont know how to set the dip switches on my driver... can anyone help me with that?
    May 2010
    313
    Looks like the dip switch settings are listed on the front of the driver
    John
    Jul 2013
    4
    indeed it is John, however i dont know what is required for my motor.... .... the motor i have is Longs Stepper motor model 34HST9805-37B2.... forgive me i am totally new to this .....
    May 2010
    313
    NEMA34 Stepper Motor - Changzhou Longs Motor Co.,Ltd
    um, says 2 amps per phase, depends on how your going to wire it I think as to how many amps to set it for, perhaps someone more knowledgeable will jump in.
    John
    Aug 2011
    12
    use a volt meter and test for the correct signal at each pin at the end of you parallel port, or at each terminal of your breakout board. If the signals are not making it out to the breakout board, nothing will ever happen. The dip switch positions should not matter if you are just trying to bench test your motors without any real load. There are plenty of good you tube videos https://www.youtube.com/watch?v=uglCm_qsojk
    that show how to pin out your parallel port. After that...it is up to you to configure the pins correctly and put the wires in the correct spot. but if you still have questions about that we can certainly help to
    Jul 2013
    4
    Brilliant!!!!!! I shall do just this.... thanks a million mcrLABS....
  1. DIY Electronics?
    By ktkg in forum Benchtop Machines
    Last Post: 07-19-2012, 02:49 PM
  2. 3 AXIS cnc router electronics
    By Denrow in forum Stepper Motors / Drives
    Last Post: 04-27-2012, 06:38 PM
  3. 4x8 new router build Electronics
    By hacker7 in forum Open Source CNC Machine Designs
    Last Post: 03-30-2012, 01:59 AM
  4. Electronics
    By Bassbuilder in forum CNC Machine Related Electronics
    Last Post: 11-16-2004, 04:34 AM
  5. Electronics help
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 07-18-2003, 03:09 PM
