587,372 active members*
4,062 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > Mach 3 motors run great in tuning mode but skip steps in G0, G1 and jog modes
    Sep 2006
    48
    Greetings,
    I've been running Mach 3 on a small shopbuilt router, and it works O/K, except it is too slow. I recently acquired an older hardly used Vytec router, forerunner to the Rebel series.
    It has an HPGL plotter driver 2 1/2D board to run it. We've removed this board and interfaced Mach 3 with the existing stepper drives.
    IN the drive tuning mode, I can get this sucker running smoothly with nice accel / decal ramping at 500 IPM in X (dual timing belt type drive), 400 IPM in Y (ball screw), and 300 IPM in Z (ball screw). It jogs just fine without skipping a step. If I try to jog from the Mach 3 jog window, it misses steps horridly at 100%, and sounds like it's grinding to death at lower speeds (say around 25%). It misses steps in G0 moves and g1 moves above about 100 IPM. It appears that it's somehow ignoring the accel / decal curves except in the motor tuning mode. I must be missing a key setup someplace.
    Any ideas?
    Stu
    1) Try turning off the toolpath display.
    2) Try increasing the pulse width in motor tuning to 10-15.
  1. 12 tooth pinion direct drive 1/8 micro step Whats my steps per inch???? motor tuning
    By greenjeens in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-26-2013, 01:50 PM
  2. Help with motor tuning steps per in mach3
    By fixitdaz in forum Uncategorised CAM Discussion
    Last Post: 05-28-2012, 12:02 AM
  3. Help with motor tuning steps per in mach3
    Last Post: 05-27-2012, 10:25 PM
  4. Fine Tuning Steps / Inch
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 09-06-2011, 01:35 PM
  5. how to setup the steps per unit in config->motor tuning
    By lucky021 in forum Canadian Club House
    Last Post: 05-06-2010, 07:04 PM
