586,061 active members*
4,361 visitors online*
IndustryArena Forum > Hobby Projects > Steam and Stirling Engines > converting 4 stroke lawn mower to steam
Results 1 to 17 of 17
    Nov 2009
    105
    Hi, this is first attempt. I have no experience with steam. I built a rotative beam and I need input power. I plan to drive a small generator. After I get it to run I will spend some time to make it look better. Any suggestions welcome.
    Jan 2010
    485
    How did the wind turbine power controller end up? Haven't seen any post for quite a while.
    Nov 2009
    105
    Quote Originally Posted by packrat View Post
    Hi, I completed the VAWT project. I tested my MPPT circuit and two other MPPT circuits from other designers. The MPPT circuit for a permanent magnet alternator is different than the solar MPPT circuits. You have to run the buck converter in discontinuous mode and for my PMA a 25 to 30% works best and does not stall the turbine.
    I live in a low wind area so I am trying steam.
    Nov 2009
    105
    Hi, modified the cam shaft using JB weld. The four stroke is now a 2 stroke. I should be able to test the conversion with air in a day.
    Are there any DIY cam shaft grinder plans availible???
    Nov 2009
    105
    Valves are opening at the same time. not good
    Nov 2009
    105
    first air test, no output torque
    Jan 2010
    485
    I haven't seen anyone do it this way. The standard ICE valves wouldn't seal tight enough, I don't think. Back in my hippy, Mother Earth News days, there were plans and even the parts to do this available. They did it by making a new cylinder head. The head used a shutle type valve and blocked off/sealed the original valves. The shuttle type valve is like a steam train uses.
    The problem with using the original valves is they are made to seal when under pressure from the cylinder. With no pressure in the ports. Using it with steam or air, the intake valve is always going to fight the pressure, unless you use a heavy enough valve spring.
    Have you seen this site? Lot of good info there. (ENGINE CONVERSION) Converting a two cyl. air compressor into a steam engine
    Nov 2009
    105
    Hi, thanks for info. This is just a first attempt to learn what is require. The BS motor had not worked in decades and was heading to the scrap pile, good enough for the learning experience. It looks like the boiler will be the real challenge.
    I was looking at a monotube boiler project on youtube. It used a reservoir and a small pump to add water to the boiler. Still searching for boiler requirements to make it safe. Suggestions welcome
    Nov 2009
    105
    Hi, running better. Now I need a boiler.
    Nov 2009
    105
    Completed boiler fabrication, safety is a real concern.
    Nov 2009
    105
    Hi, just a short video showing boiler leaks. Todays test revealed some problems. The fire is to small. The steam drum is to small. I have to find a way to stop the leaks. The pump needs to be improve, when the boiler is at pressure the pump does not have enough pressure to add water to the boiler.
    Nov 2009
    105
    Hi, first run of engine with monotube boiler. Runs out of steam after 30 seconds. I have to improve the rocket stove and water feed pump. Suggestions welcome.
    Nov 2009
    105
    Quote Originally Posted by Burnit0017 View Post
    The JB weld did not last long. I had to braze the additional lobes.
    6855
    WOW that is really a great Idea!
    Nov 2009
    105
    Hi, the end goal is to generate electricity using a permanent magnet alternator.
    There are problems areas. The engine oil pan fills with water, the run time is really short, and finding or fabricating a water feed pump capable of supplying water to the boiler when it is under pressure. I am currently working to solves these problems and suggestions are welcome.
    the idea is from other projects on youtube
    Nov 2009
    105
    Hi, I now have a working system. The mono tube boiler works well as long as there is adequate fire and water is being pumped into the boiler.
    The ICE converted to steam works well for a low cost learning tool but the oil pan fills with water and lubrication is a problem.
    I am now fabricating a more traditional engine.
    Attachment 207606
    I am having problems drilling the 1 inch hole needed for the piston cylinder, what is the best method for drilling a large diameter hole in a block of metal????
    Suggestions welcome
    Nov 2009
    105
    Re: converting 4 stroke lawn mower to steam
    https://www.youtube.com/watch?v=3J9SEBgoTMY
    Hi, I spent the winter fabricating a small 2 cylinder, single stroke. It has a 2 inch stroke with 1 inch bore. It should work well with the mono tube boiler.
  1. More lawn signs
    By cncadmin in forum EnRoute
    Last Post: 01-25-2014, 10:42 PM
  2. rc lawn mower
    By em123 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2008, 07:35 PM
  3. Wangle lawn Mower?
    By godspeed in forum I.C. Engines
    Last Post: 09-10-2007, 08:30 PM
  4. Lawn Chair Larry
    By Geof in forum Community Club House
    Last Post: 07-09-2007, 02:13 AM
