588,570 active members*
5,236 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > kitamura stuck in machine unready
Hybrid View
    May 2008
    84
    Kitamura My3, Yasnac I-80. Machine is stuck in e-stop alarm. 2ndLS allows servos to start, then goes to machine unready (alarm 2190). Is this an axis limit switch problem? The DGN values show the axis switches are correct.
    Machine was moving the x & y axis fine, but the z-axis was locked up. Now all 3 are locked.
    Any suggestions?
    Aug 2012
    38
    Is one of the limit switches stuck? There should be two switches for each axis one is a home switch the other is a hard limit. If it’s a switch it would be a hard limit switch, pull up the ladder and confirm that all hard limit switches are either open or if any are closed. When all axis are off home position then all switches in the ladder would show open.
  1. Kitamura Mycenter 3
    By machinescnc in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2012, 11:59 PM
  2. Kitamura help
    By darson in forum Fanuc
    Last Post: 08-08-2011, 05:53 PM
  3. New (to us) Kitamura HX400i
    By stucaruk in forum Kitamura
    Last Post: 03-29-2011, 01:15 AM
  4. Kitamura HMC
    By dhiruj in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2010, 04:29 AM
  5. kitamura
    By bkia in forum Uncategorised MetalWorking Machines
    Last Post: 03-09-2010, 04:02 AM
