603,882 active members*
4,407 visitors online*
Results 1 to 8 of 8
    Mar 2006
    4
    g76 thread cycle
    What would the G76 lines look like for a 2-1/2"-8UN thread External and internal? Anybody looking for a programming job a motorsports environment?
    4826
    What kind of controller? There are a couple of different formats in common usage, known as 'one line' or 'two line' formats. The exact variable syntax can also vary slightly in address (letter) name, and decimal or non-decimal formatting of some of the numbers in the command line.
    Mar 2006
    4
    Fanuc controller
    Quote Originally Posted by HuFlungDung
    The typical lines would read
    G97S700M3
    G0X2.7Z.1M8
    G76P010060
    G76X....Z-.....P...Q...F.125
    I'm just not sure what the best numbers for the min diameters are for external and internal threads. I want to make sure and get it right because I don't have a gage. The good thing is I'm making the nuts that go on the hubs.
    Nov 2005
    172
    On Fanuc controls, the previous post is correct for 0t, 16t and 18t style controls.
    For 10t,11t and15t a one line multiple repetive cycle variant is used;
    X= minor diameter
    Z=end point of chaseI
    I = taper over length of thread
    K=single depth of thread
    D=depth of first pass
    A=angle of thread
    P=infeed type
    G97S700M03;
    G0 X ( rapid point in X larger than major diameter) Z (rapid in Z)M08 (coolant on);
    G76 X (minor diameter) Z (end point of chase) I (taper if needed) K (height of thread)
    D (depth of 1st pass) A (angle of thrd) P (infeed method)
    You can also use the standard thread cutting canned cycle G92, you rapid to your start point as above, then in the next line state;
    G92 X (depth of first pass) Z (end of chase) F (feed rate = pitch)
    X (depth of 2nd pass)
    X (depth of 3rd pass)
    .......................repeat until minor diameter achieved
    Advantage of this strategy is you have complete control over your pass depths. Disadvantage is it is a little more code to have to deal with.
    Hope this helps.
    MarkT.
    Sep 2006
    39
    I don't know if this thread is still active but what are the other parameters here?..Q,F...this was written by a previous employee and should cut a 3/4 NPT but the tool does not follow the same path each pass. This is for a Haas tl2
    G76 X0.9601 Z-0.7935 I-0.031 K0.0541 D0.015 P1 A60 Q29000 F0.0714
    2932
    Quote Originally Posted by lostpinky View Post
    It's a 5-1/2 year old post... I'm guessing he's solved the problem. The one thing I don't like about this forum is that half the time, there's no feedback from the original poster that the problem is solved, and which suggestion/advice solved it.
    Q is the thread start angle, and F is the feed per revolution (in this case, 14 pitch, or 1/14)
    May 2007
    1003
    Quote Originally Posted by dcoupar View Post
    x2
    Bugs me too.
    Sep 2011
    6
    EXTERNAL 2.5"x8 UN 2A
    TURN MAJOR TO 63.248MM
    G76P020060Q160R.05
    G76X59.555Z-40.P1720Q300F3.175
    INTERNAL 2B
    BORE MINOR TO 60.388MM
    G76P020060Q160R.05
    G76X63.863Z-40.P1720Q300F3.175
    CHANGE THE Z FOR THE END POSITION OF THE THREAD. YOU MIGHT HAVE TO LOOK AT DEPTHS OF CUT DEPENDING ON MATERIAL BUT THAT'S THE GUTS OF IT. HOPE IT HELPS
