603,311 active members*
3,370 visitors online*
IndustryArena Forum > Material Technology > Material Machining Solutions > How to hold Pinion wire for turning
    May 2013
    5
    Im fairly new to the forum but have a little experience with home machining. I have about a foot of 64pitch 8 tooth brass pinion wire that i need to turn down to make some tiny spur gears. Is there a correct way to hold pinion wire in a lathe without damaging the stock?
    thanks
    Phil
    Jan 2010
    485
    Standard lathe collets are all I've ever used.
    May 2013
    5
    I guess i was worried because you are only gripping on the ends of the teeth and thought it would damage the brass in a collet. I will give it a go!!
    I was half expecting some kind of custom collet which had been EDM'd to the profile of the wire!!
    Thanks for taking the time to answer
    May 2013
    5
    Thanks for the info!! I was just concerned with damaging it, because of it size and the fact that it will only be gripping at the tips of the teeth.
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  3. Hold to hold tool holder while loosening nut
    By NXTwoThou in forum CNC Tooling
    Last Post: 02-24-2009, 10:15 PM
  4. turning .003 diameter brass wire
    By camtd in forum CNC Swiss Screw Machines
    Last Post: 06-14-2008, 06:15 PM
  5. fadal slide hold turning on
    By matt88 in forum Fadal
    Last Post: 03-10-2007, 02:55 PM
