586,036 active members*
3,540 visitors online*
Results 1 to 12 of 12
    2139
    spindle electrical noise
    Guys,
    The electrical noise from my router/spindle on my machine causes my limit switch circuit to false trigger. I put a ferrite donut on the limit switch circuit cable with no luck. The limits are NC and the input goes low when there is a problem. All the cabling on my machine is shielded EXCEPT for the limit switch circuit. Is there a better solution of do I need to rip out the cables and replace them with shielded?
    If I turn down the spindle RPM the problem goes away. (80% or below is fine).
    Is there something I can put in the sindle circuit that may help?
    Eric
    I wish it wouldn't crash.
    Jul 2003
    246
    You can use noise canceller at the button inputs. Also this is good for debounce problems.
    Yes you must use shielted cable for all input pins of controller.
    Aug 2003
    69
    Switch problem,
    Eric,
    Do you think it's purely an electronic problem, like strong (electro) magnetical induction in cables, or is it a vibration in the construction that might not be detected by touch or hearing. That could allso trigger a switch. Only one occurance would halt the software as well.
    With an oscilloscope you could try to find irregularities in the signals. The ferrite ring was the first most obvious thing to try. Would it be a good idea to ground your machine to a clean earth? Ring shaped constructions could run large induction currents, like your gantry perhaps? You could go for magnetically operated switches like reed relais?
    I dont know, it could be a million things, just trying to think my way out of this one
    Keep us posted, this could affect more builders.
    Good luck...
    Ed.
    Not the horse, of course of course...
    Building my own Scrapheap challenge CNC, or is it Junkyard wars CNC?
    Aug 2003
    69
    Lightbulb
    Come to think of it,
    You tried to find the solution near the switches. Wouldn't it be more obvious to try to solve it near the source of the trouble?
    Maybe putting more ferrite cores close to your spindle? Is the spindle earthed, like maybe the rest of the machine? If it has a steel / aluminium case it probably should be?
    I know my spindle has a plastic casing, so no shield there!
    Ed.
    May 2003
    325
    If your spindle motor is dc, mount small capacitors (0.01 uf or so) on the motor terminals. Use 3: one from each terminal to the case of the motor, and one between the terminals. This will reduce a lot of the brush noise.
    Since your limit switch is n.c. and goes low to activate an error, there must be a pull down resistor, you could connect the n.o. contacts on the switch to ground and use a pull up resistor (5-10k) on the ckt. This would solve a vibration problem.
    robotic regards,
    Tom
    A clinician learns less & less about more & more until he knows nothing about everything. A researcher learns more & more about less & less until he knows everything about nothing.
    - - anonymous
    4826
    I had a similar problem, and it was due to vibration. I replaced the "El cheapo" limit switches installed by the original retrofitter, with some heavier duty units and solved the problem.
    2139
    It's an AC Porter cable spindle. I dont *think* it's vibration. I jumpered the z axis limits and still had the problem. I beat on the machine with my fist and had no faults.
    I suppose I need to run shielded cable.
    The ferrite donut is installed as close to the breakout board as possible.
    The machine and spindle are grounded.
    How about a small value cap in parallel with the limits?
    Eric
    Apr 2003
    99
    I'd go for bunalmis' circuit. I think you're dealing with transient noise, actually it's a pain in the you know what.
    Keep it simple, use a 4.7k pull up resistor, that is one end of the resistor tied to +5 volts and the other end to the input signal, and a .01 microfarad capacitor tied to the input and ground.
    Use it near the input and of course, by all means use shielded cables. Sometime it's a good idea to use ferrite core in series of the input signal too.
    I've had a similar problem testing high speed actuator for transient analysis for aircraft applications where the transient spikes would mess up the computer.
    2139
    There is a pullup in there. I will let you all know how I make out. Thanks for the help.
    Eric
    2139
    Problem solved with a cap between the limits and ground at the terminal strip. Thanks everyone!
    Eric
    Aug 2003
    72
    Hi. I have the same problem on my router. When pushing the kress spindle hard (I guess it draws more current and therefore generate more electrical noise) it triggers the limit switches in MACH3.
    What cap did you use and did you mount it over the limit switch loop close to the break out board (between minus and plus on each limit switch) or did you connect the plus to earth plane?
    BR / Anders
    24221
    The info I have seen on Kress spindles is they are double insulated, no ground connection.
    Therefore you cannot ground the frame to earth ground bonding point?
    Al.
    Albert E.
  1. Noise in Bridgeport 2J head (audio file included)
    By daytrader in forum Bridgeport / Hardinge Mills
    Last Post: 08-03-2016, 07:03 PM
  2. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2010, 09:57 PM
  3. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 04:41 PM
  4. Porter cable spindle noise reduction or alternative?
    By paulr4 in forum DIY CNC Router Table Machines
    Last Post: 03-26-2005, 07:56 PM
  5. Electrical noise.
    By MrBean in forum CNC Machine Related Electronics
    Last Post: 01-14-2005, 01:25 AM
