603,810 active members*
3,150 visitors online*
Results 1 to 8 of 8
    Sep 2005
    20
    About Importing Files
    The CNC machine for my senior design class is built and working fine with Mach 2. However all of our machining so far has been either by MDI or using the wizards. Ideally we would need our parts designed on AutoCad, Pro-E, or Solid Works but we've had some problems. I know Mach 2 takes dxf, hpgl, bmp, and jpeg files, and none of our CAD/CAM software seems to be capable of exporting these. If anyone uses the aforementioned CAD/CAM with Mach 2, could you help? Thank You.
    Apr 2005
    78
    Autocad can save in DXF. Do you have Autocad or one of those clones? I have autocad 2002 and Mach 2 and it works perfect. - Zachery
    35494
    If you're thinking of exporting 3D parts and loading them into Mach3, it won't work. for 2D .dxf's, with AutoCAD, choose Save As, and change the file type to R12 .dxf.
    With Pro-E AND Solidworks, you may have to create drawings of your parts and export those as .dxf's.
    I wrote an AutoCAD macro that will export g-code from within AutoCAD. Works with 2002 and newer. Here's the link to download, and the thread.
    http://www.cnczone.com/forums/attach...achmentid=7768
    http://www.cnczone.com/forums/showthread.php?t=8226
    Sep 2005
    20
    How would you put a 3D file into Mach 2, say if you want to do some 3D surface work? Is Mach 2 only capable of 2D milling?
    35494
    Use a cam program. MeshCAM is cheap. www.meshcam.com
    Sep 2005
    20
    Thanks, that AutoCAD macro works great. I have another problem though. Over the weekend our CNC machine was working great. But when we ran it again today, the motors seemed to be moving in steps. What I mean is, the axes will move like an inch, then stop, then continue. The cuts are still coming out accurate, but it is kind of irritating compared to the smooth, continuous motion we used to have. Is this a Mach2 problem?
    35494
    Are you in exact stop mode by chance? Is there a G61, or G64 at the top of your screen (where all the codes are displayed)
    Mar 2006
    52
    I am having similar problem. When 'I convert a jpg and run the program (mach 3) the stepper motor slows down and speeds up etc. the speed is like a wave. In the "State" box constant velocity is checked. What is up with that?
    If it doesn't work BUY BIGGER MOTORS!!
