603,388 active members*
2,698 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Looking to build from plans or kit 5x10 table - reccomendations? CNCRP or Mechmate?
Results 1 to 20 of 20
    Jun 2013
    25
    Hi all,
    I'm relatively new to the CNC world having picked up my Probotix V90 table a few months back. Now that I'm fairly familiar with the machine and the software (Mach3 / VCarve Pro) I'm absolutely ready for a much larger / capable table. I do a fair amount of woodworking - signs, cabinets, speakers, furniture and so forth. My favorite stock being a speaker designer/builder is Baltic Birch in 5x5 sheets so I'd like a 5x10 table to accommodate those as well as the normal 4x8 ply material. My background is in IT/programming/comp sci and I have a fair amount of mechanical/electrical experience as well. I also have a fair amount of help handy from friends who are ME/EEs.
    I've been looking hard at a custom CNCRP 5x10 'kit' but I'm also considering a mechmate build which look like a lot of fun as well. I have the plans and have been looking through them. I don't currently have a welder nor do I know how to weld but I'm always willing to pick up new skills for projects and/or find someone who can help. I have a brand new 12x32 shed/workshop which I had built just for my woodworking and to house the new CNC. I'm not in any huge rush to complete the project and want to do it right with no regrets. A 3 axis setup would do just fine for my purposes, perhaps with the option to add a 4th later on. I'm a big fan of the R&P setup with a ballscrew on the Z. I'd like to be efficient and will be using NEMA34 motors for sure. My budget for the build is a 6-8k target including table and all electronics. I'd like the ability to add a vacuuam table later on as well.
    Any insight is very much appreciated. Thanks for your time.
    Andrew
    Thornton, PA
    Sep 2012
    19
    I don't know much about Mechmate, but based on good customer service and communication, I would recommend CRP. I haven't bought my machine yet, but CRP has been more than accommodating with my questions via emails. CRP even called me. I didn't expect that. That aside, unless anything changes in terms of size, my machine from CRP will be a custom PRO 5'x3'.
    Southern California
    Jun 2013
    25
    I've only heard good things about CRP as well. I had emailed back and forth with Cory a few times on a custom quote and response time was excellent.
    Sep 2012
    19
    Not sure you're going to be able to stay under $8K total. It'll be close. I'm pushing $8k for my smaller machine with everything but the computer. I'll have to re-evaluate to bring down the price. According to CRP, the Nema 34 plug and play kit really bumped up my price.
    Southern California
    Jun 2013
    25
    You're probably right. I'm about at 6k for just the pro kit with extrusions and shipping. I still need to build a table/base, electronics, dust collection, cable management, and spindle/vfd. Looks like this might be a 10k project before becoming a reality.
    35494
    I would think that a Mechmate would be quite a bit cheaper, but a lot more work.
    Jun 2013
    25
    There is no doubt there. The steel c-channel rails cost a fraction of the price of aluminum extrusions of the same length. The added labor of having to cut, grind, and weld is for sure no easy task. The mechmate does seem like a very solid and rigid machine though when completed and there are a lot of happy users out there.
    I should have electric up and running in the new shop in another 2-3 weeks. By that point I'd like to have chosen a design so I can start constructing the base table.
    Apr 2007
    8082
    Building the MechMate gantry at home is no small task. Two of my friends have jointly built a MechMate 5' x 10' machine. They ordered a gantry kit that was prefabricated by someone who does it as part of a steel fabrication business. My friends built the framework in a home garage. They have been very happy with theirs.
    MechMate machines have a large following of builders worldwide. So does the CNCRP extrusion machines. Personally, I like the open flat top CNCRP design better for working with anything on the table top. It's easier to me than working down inside of a boxed in area. The vertical walls of the MechMate probably contains any flying debris better though. It's a personal preference that needs to be considered for your first machine.
    CarveOne
    http://www.carveonecncwoodcraft.com
    Apr 2009
    5516
    Not only will you have likely to farm out the task of cutting steel plate for the MechMate, but you will also have to have parts precision bent. The CNCRP is as bolt-together as you can get for the mechanicals of a CNC. Also the CNCRP plans are open source, so you can buy the parts they sell and ger your own extrusions. Both machines have large followings. The CNCRP guys are frequent posters in the Forum as well...
    Apr 2007
    8082
    One other MechMate issue I remembered is the V rails. Builders have come up with angle grinder fixtures that they use to make the V shaped edge of rails. That was one of the problems they had during construction. There is probably a supplier of those by now, at additional cost.
    CarveOne
    Jun 2013
    25
    I've been looking into grinding the rails on the mechmate as it seems to be the biggest point of trepidation amongst builders. They can be purchased pre ground, but the cost is quite a bit higher. There is also a vendor that sells all of the laser cut plates as a kit as well as motor brackets, bump stops, and pre machined bushings.
    With that said, I'm leaning more toward the Extrusion based CNCRP kit at this point. I like the fact of not having to acquire steel and a welder and not having to move in each piece (heavy) into my shop. Is there any downside in rigidity with the aluminum? I will be building a substantial wood base for it soon.
    Here's the plan at this point:
    CRP custom pro kit to give me a full 5' x 10' cutting area (maybe a little more on the X just in case)
    CNCRP Nema 34 DIY kit - with enclosure includes 960oz motors, gecko 201x drives, 48V 21A PSU
    Custom built table - 4x4 or 6x6 based
    80mm China spindle and VFD (maybe Hitachi X200)
    Kent Dust shoe
    Cable track management
    Sep 2012
    19
    Quote Originally Posted by Gorilla83 View Post
    Kent Dust shoe
    This recent thread could give you a little information on defection. As my CNC router will have 60" of y axis movement. Also, based on a CNCRP PRO kit.
    Regards,
    Ron
    Southern California
    Jun 2013
    25
    Ron - thanks for the link and thoughts. It looks like we should both be solid deflection wise on the Y.
    Also to all - water cooled vs. air cooled spindle? Don't see too many here running without the water cooling. Thoughts?
    Sep 2012
    19
    My apologies. I forgot to include the thread in my last post:
    http://www.cnczone.com/forums/cnc_ro...ml#post1347390
    Southern California
    Jun 2013
    25
    OK - aside from my dust collection setup and some odds and ends, the new shop is pretty much ready to receive the new CNC table. The more I think about it I really wouldn't need much more than a 5x8 cutting area. This would allow me to cut 5x5 as well as standard 4x8 sheets, as well as save some money and space in the shop.
    I've pretty much narrowed down my choices to building a CNCRP kit or buying a used Shopbot Alpha.
    Any reason to extend it out to the full 10 foot on the X axis? Leave additional room for a Z touch plate or something?
    35494
    If you're not cutting 10ft sheets (or 10 ft parts), then there's no reason to have a 10ft table. I'd go a few inches longer than 96", though, maybe 99"-100". I'd want at least an inch extra on all sides of a 4x8 sheet.
    Jun 2013
    25
    Trouble is I'm not cutting anything in 10 foot sheets as of now, but am I missing any future opportunities? Long board/trim work? It's likely this is the machine I will have to (read: Wife approval) keep for a while so I want to have as few regrets as possible. At the same time I'd be happy to save a few bucks in the process.
    35494
    We have a 5x12 machine in the shop I work at, and 99% of what we cut is 8ft long. The only thing we cut that's longer on a regular basis is solid surface, which comes in 30"x144" sheets.
    Jun 2013
    25
    Thanks Gerry, good input. It seems like 8' is a good length to work with. I'd be happy to pick up those extra 2 feet in the shop.
    Jun 2013
    25
    Going to start next week on building the base for my 5x8 machine. I'd like to use steel and funny enough I'm looking to learn to weld and work with rectangular stock as part of the project. Been taking a bunch of welding courses online and doing all the reading I can. I'll start my first 'practice' sessions this weekend at my dad's shop.
    As a bonus - at the family's shop there are a bunch of pallet stands laying around that use 4.5x2.5" stock that I can use - freebies.
  1. Replies: 29
    Last Post: 01-27-2014, 05:49 PM
  2. PrecisionPlasma/CandCNC 5X10 table build
    By Teknition in forum Waterjet General Topics
    Last Post: 04-01-2013, 08:34 PM
  3. Amateur 5x10 waterjet table build
    By chimpera in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 10-25-2012, 03:39 AM
