586,119 active members*
3,629 visitors online*
Results 1 to 12 of 12
    Nov 2005
    16
    Second parallel port?
    Hi i need 2 parallel ports for EMC. But hier is the problem, the second parallel card that i buy and put it in comp. Comp. does not to recognize it. How to set second parallel card to adress 278? I need it for lube and mist!
    So, what i need is that my comp. recognize second parallel port. And then i need to put it on adress 0x278!
    Help, pleas
    Matej
    tnx, Matej
    Feb 2006
    77
    No, first you need to put it's adres at 0x278, to be recognised by the computer as LPT2. Otherwise you have 2 LPT1 ports. On your card there should be a jumper where you can choose between LPT1 and LPT2. Out of the box it will be configured as LPT1.
    Carel
    Nov 2005
    16
    jumper? where on my motherboard? the second Parallel port is on PCI slot!
    And where must i put adres 0x278?
    tnx, Matej
    Feb 2006
    77
    No, not on your motherboard. The PCI card has an address and is recognised by the Bios at startup. This address must be unique and be in this case 0x278. An LPT1 has the address of 0x378. So to make the card unique an address line (8) must be changed from 1 to 0. Normally this is done with a jumper on the card. Otherwise you should contact your supplier or RTFM.
    Carel
    Nov 2005
    16
    Oh, i undestand now, i tray this. TNX
    Whats line (8) ?
    On PCI parallel card is NO jumper !
    tnx, Matej
    Aug 2004
    421
    The address isn't necessarily 0x278. You have to go into your device manager to find out what address your computer gave it. I had this problem with mine, it actually gave it some kind of letter combination.
    If you try to make everything idiot proof, someone will just breed a better idiot!
    May 2005
    162
    What install of EMC are you using? If it is a BDI installation then when you get xwindows running go to system-info from the menu at bottom left, if your PCI p port cards are detected they will be assigned hexadecimal addresses,
    LPT1 ; paraport0
    LPT2 : paraport1
    and so on, I have two PCI pport cards in my system so the CNC can run off of the two add in cards and not the built in parallel port.
    Once you have the addresses for you card, edit the ini file for your EMC installation and tell it where the ports are.
    Nov 2005
    16
    I use BDI 4.38 KDE
    parport0 on adress 0x378-0x37f
    My computer recognise parport1 on adress c000-c002
    But i need 0x378 and 0x278, or not?
    tnx, Matej
    May 2005
    162
    No, you configure the EMC ini file to match your parallel port addresses, I'll try and get a copy of my ini file to you, it will give you some ideas how to config some options for your own system.
    May 2005
    162
    Here's the ini file from my system.
    Do not use it on your hardware without understanding what you need to change first as damage may ensue.
    Attached Files Attached Files
    Nov 2005
    16
    OK, tnx i will look at the options!
    tnx, Matej
    Nov 2005
    16
    TNX, now works
    tnx, Matej
