588,099 active members*
5,184 visitors online*
    Mar 2005
    266
    TAIG can be used horizontally!?
    I was trying to work out a way to drill holes in the end of "tall" parts. First thing to come into mind was that I could tilt the Z and drill at an angle using X,Z axis rather than just the Z but that also meant I would have to fix the part at the same angle. I took the spindle mount off and turned it sideways and voila I can use the X for drilling parts the only problem I can see with this is that the motor is hanging very far to one side. In the pic evertything looks a little crooked its not an illusion everything is I was just taking a quick pic...
    I have actually considered doing the same, but was worried about the motor hanging way out there like that. I suppose it could be done, just make sure your spindle axis is perfectly parallel to the table though (will take some tweaking with a dial indicator) otherwise your hole are going to be at a slight angle and oblonged.
    Oct 2004
    168
    Yes, you just turn the dovetail mount 90 deg.
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
