586,096 active members*
3,667 visitors online*
Results 1 to 11 of 11
    Sep 2009
    11
    Ethernet SmoothStepper - Mach 3
    I'm having issues with this thing.
    I can not get past the screen that prompts you with CTFTP::Wake up client board dows not reply.
    I clicked "no" and put in 10.9.9.9 and it simply won't connect.
    I installed plugin version 10H2d1a and 10hd2 both with the same result.
    I have my computer setup to IP 10.9.9.1 but also tried using 10.9.9.8. I have tried this on a laptop and a desktop with the same result. I have used a crossover cable and also tried using it through a switch. The switch and ethernet ports light up so I know its got a connection. I can ping 10.9.9.9 with no problem. I can connect the Configuator and save the results to the smooth stepper so I know it can talk to it. I have windows firewall completely turned off. I tried doing this on both my laptop and the desktop.
    I can't see this being something wrong with my pc setup because both a laptop and desktop were tried.
    Any ideas would be greatly appreciated.
    Jan 2013
    306
    Have you tried this step by step guide?
    http://www.soigeneris.com/Document/W...othStepper.pdf
    I never had any issues installing. was up and running first try.
    Will be installing on a new machine this week so hope it goes the same.
    Sep 2009
    11
    I also made sure the smooth stepper is in WakeUp Mode by naking sure the jumper is not on both pins.
    Sep 2009
    11
    I looked over that document. The only thing I see different is it says to enter in the IP address AND 255.255.255.0 when you configure the plugin. Do you really do that or do you just enter in the IP address?
    Jan 2013
    306
    I do not remember if that was there when I set it up or not.
    If there is a place for it then yes.
    The important part is that the PC and ESS are on the same subnet.
    Sent from my iPad using Tapatalk HD
    Sep 2009
    1856
    dont forget reboot
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Sep 2009
    11
    I looked it doesn't have a place for the subnet mask. In any case I made sure the PC and ESS are on the same subnet. I tried 10.9.9.1 and 10.9.9.8 just for grins. I also rebooted many times trying different things to get it to work.
    This is a bummer...strange I only seem to be having this issue, and on two different machines.
    Sep 2009
    11
    Problem resolved....
    I had sonicwall VPN client installed. It will not work with that installed.
    May 2005
    3920
    Quote Originally Posted by SteveSy View Post
    Well that sucks! I wonder what Sonicwall was doing to cause this issue.
    Sep 2009
    11
    The VPN Client modifies the driver for encryption purposes. Not sure why this has an effect on smooth stepper unless he's talking to it low level through code. It doesn't impact me too much. The PC Mach is on has been re-purposed to be used for CNC work. I probably need to just wipe it and stick exactly what I need on it.
    Mar 2009
    533
    I didn't use VPN on my machine and ESS works fine for me. My mini_tower machine uses XP.
    I could see encryption being a problem. ESS doesn't de-crypt the packets, since it is neither a VPN client nor a VPN server. Hence it can't use encrypted data. I'm also not well versed with VPN to really know for sure.
  1. help smoothstepper ethernet!
    By Cam4ge in forum SmoothStepper Motion Control
    Last Post: 04-30-2013, 11:58 PM
  2. DMM Drives and SmoothStepper Ethernet
    By vertcnc in forum Dmm Technology
    Last Post: 03-09-2013, 03:53 PM
  3. Ethernet Smoothstepper with encoders
    By nicubila in forum SmoothStepper Motion Control
    Last Post: 12-11-2012, 11:45 AM
  4. Smoothstepper (ethernet)
    By t300 in forum Novakon
    Last Post: 09-08-2012, 02:43 AM
  5. Mach3 Plugin for Ethernet Smoothstepper
    By dwilson26 in forum SmoothStepper Motion Control
    Last Post: 01-31-2012, 07:35 PM
