588,644 active members*
5,107 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Intelitek ProLight thread cutting??
    Mar 2008
    25
    Seems I can't cut threads. Machine does not like Mastercam canned program? I am able to post the thread program but lathe does not follow.
    Any suggestions/help would be appreciated.
    Thanks in advance.
    Nov 2009
    4415
    Does it show the moves but not execute them? Setting in mach? Mastercam forum might be best.
    Mar 2008
    25
    i tried this a few months ago and not sure about the moves on screen? i'll try it again and let you know. what do you mean by "Setting in mach?" i do have post in Mastercam regarding this issue.
    thanks in advance.
    Nov 2009
    4415
    Are you using Mach 3? Typically there is an ability to do a simulation. It will help to visualize exactly what the machine is going to do. If you are feeding MasterCam Gcode straight into the original electronics the machine will probably require a custom post processor. My familiarity is with Mach 3 and there is plenty to learn there too.
    Mar 2008
    25
    Re: Intelitek ProLight thread cutting??
    not familiar with Mach 3? upon further investigating, seems even intelitek program won't function. spindle does not start with the switch in the "computer" position. then none of the G32 threading moves happen either. I'm begining to think its the software or machine? thanks for your help.
  1. Intelitek 3D Protoypes with BobCAD CAM
    By aldepoalo in forum BobCad-Cam
    Last Post: 08-31-2013, 02:06 PM
  2. Intelitek VMC-0600 Tool Holders
    By latenorgreat in forum Benchtop Machines
    Last Post: 11-01-2011, 03:58 AM
  3. Prolight Intelitek or Benchman CNC Mill Collets
    By megclay in forum Benchtop Machines
    Last Post: 09-30-2011, 10:15 PM
  4. Thread cutting
    By Ognian in forum FeatureCAM CAD/CAM
    Last Post: 01-16-2009, 12:01 PM
  5. Intelitek 0400 Lathe and Tool Changer
    By Too_Many_Tools in forum Mini Lathe
    Last Post: 08-24-2007, 08:04 PM
