586,545 active members*
3,215 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G320 accelerates too slowly
    Mar 2004
    31
    I have two G320 drives. One of them seems to be accelerating much slower than the other given the same step rate. The gain, damp and limit settings do not seem to affect the acceleration and currently I have both drives set to roughly the same settings. How can I go about troubleshooting this?
    Apr 2004
    135
    Quote Originally Posted by ticica View Post
    Have you tried swapping motor/encoder between G320 drivers to see if the symptom follows the motor instead of the G320?
    Regards,
    Steve Stallings
    www.PMDX.com
    Mar 2004
    31
    Yes I did. The problem follows the G320. Thanks.
    Can you explain further what "accelerating too slow" means? Do you have the Torque Limit trimpot turned fully CCW?
    Mar 2004
    31
    My bad. It does not seem to be an issue with the drive. The source of the step/direction (kflop) seems to be doing something non-obvious to me.
  1. Slowly losing power.. troubleshooting.
    By DLDude in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-13-2012, 01:52 AM
  2. Help... I'm losing my Z-axis zero slowly
    By Sciome in forum DIY CNC Router Table Machines
    Last Post: 10-27-2011, 10:38 PM
  3. running steppers slowly
    By stirling in forum Stepper Motors / Drives
    Last Post: 04-17-2008, 07:30 AM
  4. Getting my V2XT started (very slowly)
    By LandCruiserLuke in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2008, 10:38 PM
  5. Coolant leaking slowly on back of VF3
    By Rocko1 in forum Haas Mills
    Last Post: 12-07-2007, 12:38 AM
