588,385 active members*
5,168 visitors online*
    Aug 2013
    3020 Spindle Motor not working
    Hi has anyone had any problems with a Chinese 3020 Engraver the spindle motor stopped after day 2 and they have replaced the motor but not fixed thus must be in the board. I have suggested to them that they need to replace it but to date nil response. All X and Y work no problems but the spindle link from board to plug is OK and tests clean.
    Any suggestions?
    Clive
    Oct 2013
    Inside the control box enclosure - you likely blew the spindle fuse.
    I believe they're 5A fuses (220V rated)
    Aug 2013
    10
    I did this within my first few days of ownership. Overloaded the spindle and it blew.
    Be prepared, you will possibly have fried the mosfet and in my case the ne555 timer chip went at the same time. Both are very cheap replacement parts if they have gone
    Oct 2013
    Clives - Check the fuse inside of the box.
    If the fuse is OKAY - put a volt meter on the red and black wires to the spindle motor. Measure anything higher than 5Volts as OKAY.
    You should be seeing 10-24V on those wires. If not - your board / power supply is junk.
  1. Replies: 5
    Last Post: 07-19-2013, 05:16 AM
  2. NM-145 Spindle not working
    By overrev in forum Novakon
    Last Post: 04-21-2012, 04:02 AM
  3. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  4. When working spindle motor steppers are tremble
    By umerov in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-16-2010, 03:49 PM
  5. fadal vmc 3020 spindle error
    By matosjulio in forum Fadal
    Last Post: 02-11-2009, 08:20 PM
