586,058 active members*
4,233 visitors online*
Results 1 to 8 of 8
    Oct 2013
    24
    Looking to get into engraving on guns and such
    I am a shooting hobbyist and have always been intrigued by CNC. Looking to get into laser or CNC router engraving but would like some insight on where to start. Nothing commercial just small aluminum and steel projects. Is there any brands or units to avoid? Just would like the basics run down since everything I run across on the internet is different depending on the supplier of the product. Looking for something economical but still long term usage.
    Charles
    Feb 2009
    6028
    Go with something with rotary tools. Laser wouldn't do what you want. (I'm assuming you want to back fill the engraving like browning does with gold). New Hermes makes a nice engraving machine among others.
    Nov 2012
    492
    What R U looking to do, if your looking to do engravings on the wood or plastic grips a Laser will work just fine. If you looking to engrave into the metal of the guns then Laser won't work unless you get one that will do metal.
    marcusCA Guest
    There will not be anything cheap on the Laser side to engrave in such hard materials.
    I would also recommend rotary tooling and as Underthetire mentioned Gravograph-New Hermes which have a set of machine solutions to do this.
    As a note we, at ArtClip3D Software, can run any rotary machines including the Gravograph, with the capability of projecting paths on any 3D object.
    Marcus Minor
    Application Engineer ArtClip3D
    ArtClip3D | 3D CNC Software for Router - Wood Carving Software - V-Carving - Signmaking
    Aug 2005
    18
    A laser that could do that would be in the $10,000-$20,000 range for a Chinese or $30,000 for a US.
    Or you could use a cheaper C02 laser and marking fluid if your marks did not need depth.
    Or you can use any small CNC mill and use that - from a few thousand to $10,000 for a small one.
    Oct 2013
    24
    Quote Originally Posted by Bigbird48 View Post
    Just engrave aluminum on guns and rifles. Some poly and derlin also.
    Charles
    Oct 2013
    24
    Quote Originally Posted by underthetire View Post
    Have anything you would recommend brand/model wise.
    Sent from my iPad using Tapatalk HD
    Oct 2013
    24
    Quote Originally Posted by rsilvers View Post
    Is there a decent beginner cnc engrave package of quality for around $1500 or all those online and eBay garbage.
    Charles
  1. machines to build guns?
    By Groo in forum Gunsmithing
    Last Post: 09-02-2013, 09:12 PM
  2. American Guns Show, machined gun site
    By fjbart70 in forum Uncategorised MetalWorking Machines
    Last Post: 06-19-2012, 06:28 PM
  3. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
  4. Images on a Guns Stock
    By dvdlock in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-20-2009, 06:27 PM
