Hello,
How can I use the function Intersection Curves on a STL file/object?
I read somewhere the BCC uses solid volumes and that STL is a mesh surface.
gallenat0r
Hello,
gallenat0r
You can not create intersection curves on an STL. That is a surface based option.
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
Intersection Curves is limited to Surfaces, as far as I know, and there's not a way to use it on a .stl model. There may be ways to work around that with different tools, though. Embossing, for instance, provides a some tools that can do things that might help you out.
Luke
"All I'm trying to find out is the fellow's name on first base" -- Lou Costello
lol, Al posted while I wasn't looking. Sneaky guy, that Al. Welcome back from Westec.
I was hoping for a way like the OpenSCAD function projection
Seems so easy in OpenSCAD.
gallenat0r
Nope, no way to do that with a .STL in BobCAD that I'm aware of. If you have OpenScad, you could do it there, then import the .DXF into BobCAD.
Luke
Yeah that's what I ended up doing
Maybe a feature request for V30 or V31? ;-)
gallenat0r
