603,794 active members*
3,093 visitors online*
    Aug 2007
    270
    Mach 3 running the wrong direction
    Can anyone tell me an easy way to make Mach 3 run the tool path in the opposite direction. I use Lazy Cam to set my files up to run. Some of them run around the pattern clockwise and some run counter clockwise. How can I change them so the router bit cleans the cuts better?
    Thanks Dan
    35494
    The machine follows the g-code. You need to set the direction in LazyCAM. I don't use it, so can't tell you how to do it. There is a LazyCAM manual on the Machsupport forum.
  1. Need Help! Y-axis wrong direction
    By ponte in forum Redsail Laser
    Last Post: 08-10-2013, 03:07 AM
  2. A/C Motor Turning Wrong Direction
    By sx3wiz in forum CNC Machine Related Electronics
    Last Post: 03-25-2013, 04:37 AM
  3. Z-axis only turns in ONE direction, anyone know what might be wrong?
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 03-15-2012, 01:20 PM
  4. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
  5. EZ Trak axis running wrong direction
    By spindlenut in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2010, 05:38 AM
