603,988 active members*
2,900 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > DM2016 - Any documentation or manuals
    May 2012
    6
    Hi all
    In another tread i have asked som questions about repair of a Dyna Myte 2016, is there anyone who has some documentation for this machine, manuals, tech specs and so on.
    Thank you all
    Chris
    Dec 2012
    569
    Quote Originally Posted by ValhalDK View Post
    Hi all
    Thank you all
    Chris
    the company still has tech support, its a USA number in california, 408-452-1010 Welcome to DYNA Mechtronics
    also, if you post some pictures of your machine and describe the issue, I or others may be able to help you.
    May 2012
    6
    The machine is a 2016m , and its hopefully only a display problem, see other tread , and therefor im looking for some manuals for the system, and the onboard pc.
    Sendt fra min GT-P5110 med Tapatalk
    Dec 2012
    569
    if the problem is really only the display, then it may be booting up fine and you might be able to jog the axis around or interact with the machine even if the display is blank. this would be a useful test to perform. call the tech support number and ask if this is possible.
    im not sure what sort of video output that video card has...looks like it doesnt have a standard RGA 15 pin. it appears to be ISA.
    i suppose there is a small chance you can get a very inexpensive old ISA video card and plug it in, then plug a monitor into that and see if it works. it sounds like you may be attempting that.
    as far as manuals, dyna may still sell them. call the number. or you may have luck finding them online somewhere.
    whatever you do, dont start doing anything you dont know how to undo. the problem may be very simple and you will probably make it much worse by just randomly attempting things.
    May 2012
    6
    What you explain here is pretty much what i plan to do, im trying to find a old isa vga card so i can test it out. Another problem is that im personaly located far away from the machine, so im doing alot of research until i get to the machine again.
  1. Manuals and Useful Documentation List
    By Zoner in forum Fanuc
    Last Post: 11-23-2013, 01:37 AM
  2. DYNA DM2016
    By ValhalDK in forum Dyna Mechtronics
    Last Post: 11-09-2013, 05:48 PM
  3. error 465, dyna dm2016
    By kmelektro in forum Dyna Mechtronics
    Last Post: 01-14-2011, 12:11 PM
  4. Dyna Myte DM2016 resurrection
    By dave design in forum Dyna Mechtronics
    Last Post: 08-13-2010, 05:41 AM
  5. Need Info on DynaMyte DM2016
    By Josh_Heimbuch in forum Uncategorised MetalWorking Machines
    Last Post: 04-24-2006, 02:36 PM
