603,895 active members*
5,372 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Any recommendations for a power supply for their 3 axis board?
Results 1 to 9 of 9
    Oct 2003
    208
    Question Any recommendations for a power supply for their 3 axis board?
    I just ordered the 3 axis driver board and 3 stepper motors and i was wondering if anyone could recommend a 24v power supply and instructions on how to hook it up?
    35494
    I listed 6 of them in your other thread here.
    Apr 2003
    1079
    Like ger21 said, look through his list, I would go for the most powerful one you can afford, that way it should do you if you ever upgrade your system too. As for hooking it up, there are simply two connectors on the board, one for neg and one for pos. Check the manual.
    Oct 2003
    208
    I haven't gotten the board yet. It is on its way in the mail.
    Apr 2003
    1079
    The manual is here, check page 7 for the diagram, bottom left, "J9" is where the power supply connects to. It will pay to fully read and understand the manual before you touch the board, as there are instructions for setting it up for your specific motors. Good luck!
    Oct 2003
    208
    Don't get mad but i got another question.
    Can i go to my local wal-mart and get a universal power adapter?
    Will it work? etc ...
    Apr 2003
    1079
    It would be ok if you can get one powerful enough. 24v @ 8Amps would be ok. If I remember rightly, when I had the board hooked up, my psu was 24v @ 11Amps.
    Oct 2003
    208
    I just emailed zylotex and asked for a recomendation for a 24v power supply. the one jeff recommended was 24v and 6.5 amp.
    can you explain explain the amp thing. i mean what is the minimum and why. etc...
    Apr 2003
    1079
    If the max for the board is 2.5 Amp per axis, at 3 axis (axes?) for the board, that's 7.5 Amps. Obviously you have been recommended 6.5 Amps because I'm guessing your motors are around 2 Amps each. It's good (in my opinion) to get the biggest (highest amperage) psu you can, as you will not have to buy a new one if you decide to go for bigger motors and/or board.
  1. Beginner Troubleshooting and Building Considerations
    By coherent in forum DIY CNC Router Table Machines
    Last Post: 08-13-2013, 06:05 PM
  2. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 03:40 PM
  3. 5 Volt Power Supply Tripping
    By murphy625 in forum CNC Machine Related Electronics
    Last Post: 02-28-2005, 04:05 AM
  4. Power Supply Help
    By SteinAir in forum CNC Machine Related Electronics
    Last Post: 01-05-2005, 06:58 PM
  5. Choosing a Power Supply for Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2004, 04:36 AM
