603,344 active members*
3,121 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > G540 4 axis driver ground ?
Results 1 to 7 of 7
    Mar 2007
    31
    i just received my G540 3-Axis NEMA23 381oz in PSU48V/7.3A kit from
    G540 3-Axis NEMA23 381oz in PSU48V/7.3A | Automation Technology Inc
    Just started looking thru the connections and see a ground pins in the connectors and don't see where they connect in the cable to the motor?
    I have 18/4 shielded cable with the copper wire in it. I just don't recall a ground wire on the motor.
    Where does the ground connect too?
    or does it?
    24260
    You should have an earth ground lug in the enclosure that is connected to the service ground, and motor frames and shields should be connected to this point.
    Al.
    Albert E.
    Nov 2009
    724
    That ground is the drain for the shield ground in the cables to the motors it is only connected at the driver end not at the motor end.
    It is grounded through the G540.
    JTCUSTOMS
    "It is only when they go wrong that machines remind you how powerful they are."
    Clive James
    Mar 2007
    31
    Thanks.
    Will be putting the motors together this weekend.
    Going tomorrow and pick up my mill from the ups fright center.
    Still waiting on my parts from cncfusion.
    Sent an email couple days ago and have not heard from them yet.
    Aug 2004
    3215
    I use the G540 on my G0704. Since it is a lower amp controller I added 2 50lbs struts to mine to help with Z-Axis counter balance. Works really well.
    G0704 First Run - YouTube
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Mar 2007
    31
    That looks cool, need to find more about the strut upgrade
    Sent from my SCH-I535 using Tapatalk
    Aug 2004
    3215
    I used the idea from here. CNC milling machine | design & make
    I Made my brackets then I attached the strut to the top raised the head all the way to the top and let the strut hang down to determine where to drill and tap the bottom hole in the column.
    Now this will only work without the Z-Axis flip MOD.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  1. Ground Rod Driver. How?
    By Al_The_Man in forum Community Club House
    Last Post: 05-23-2013, 07:12 PM
  2. 2 Motors 1 Axis Driver in Gecko G540
    By guy2b1 in forum DIY CNC Router Table Machines
    Last Post: 06-10-2012, 04:00 AM
  3. G540 Sheilded cable ground
    By LazyMan in forum Gecko Drives
    Last Post: 07-28-2011, 12:26 AM
  4. single axis driver and a b.o.b.,or multi-axis driver board
    By .xXACEXx. in forum Stepper Motors / Drives
    Last Post: 07-03-2007, 05:13 AM
  5. Motor Driver where to put ground?
    By Trapper14 in forum CNC Machine Related Electronics
    Last Post: 08-08-2006, 08:20 AM
