Hello, I could really do with some advice on my idea.
I do some woodworking and like the idea of having a CNC like system to speed up my production work. However I don't feel I need it to be computer controlled at this stage, so I would make a system that relied on templates with guided bearings bits / template bushings to control my cuts.
My current idea is to make a system for cutting area of 100cm x 40cm. This would be made using 2 x (25/30mm) supported ground rails for the Y axis, then 2 x 30mm ground rails mounted on bearing blocks to make the X axis. I would mount a router in the center, i'm thinking i'd use a router i've found which weighs 3.5kg and is 1100w power, my other is 2400w weighs 6kg so seems on the heavy side. Depth of cuts would be controlled by manually adjusting router depth.
What I don't really know about is whether the shafts are sufficient for this routers weight and what kind of accuracy I could expect with cutting depths and if this project is even a viable idea.
If anyone could help at all i'd be very grateful.
