603,780 active members*
2,679 visitors online*
Thread: GE 388 Lamp
    May 2006
    82
    GE 388 Lamp
    When I started in CNC I was running LeBlond Makino's with Fanuc 6M's. One of the weekly duties was to replace the GE 388 Mini-Lamps that had blown on the controls maybe one or two maybe zero would need replaced. My new job I am running a machine with a Fanuc 150i-M and the same 388 are used. Is there an alternative to the 388?
    Larry
    :cheers:
    24260
    If you can find them in that base type, Multi-LED is the way to go now, you may have to confirm the polarity on the socket.
    They make them in a few of the common bases.
    Al.
    Albert E.
    746
    It seems to me that I've seen that style of bulb somewhere with an LED intergrated into it. I don't remember the voltage, I think it may have been the local electronics surplus store. I'll keep a lookout for them.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Apr 2004
    79
    If I had something important to say it would be here.
